Alright so I'm a little frustrated at my truck for the last month. I have a 2013 f350 with 2 codes comming up. P0100-mass or volume air flow circuit and a U0106-lost communication with glow plug control module. I have an H&S tuner with the delete. I changed the MAS and it's still lighting up. The dealer is looking into it cause they didn't foresee any problems with the glow plugs either. I erase the code, shut the truck off and once I start it it's right back on! Frustrating!
Hey buddy need some help. I have a 2013 250 deleted with custom tunes & my truck is throwing same 2 codes. It's still under warranty, I brought it to ford & they won't touch it. I think they just being a**holes so my question is did ford fix yours even though it was deleted?? Would appreciate the help!!!
Ahhhh, you're deleted and you still expect Ford to cover it under warranty???
Ahhhh, you're deleted and you still expect Ford to cover your it under warranty???
Yes cause I feel neither code has anything to do with the truck being tunned & deleted. It would be one thing if i would have done changed mass air sensor & glow plugs but they are factor so yes I feel they should warranty the truck but that's just me. My remote start don't work anymore either, guess that's from tune & delete huh?? 😂
I would think as long as it wasn't directly caused by the delete and tune it should be covered. Some dealers are better than others thou. I believe the command start will not work if you have an active cel.
I agree thanks. Gonna talk with them again tomorrow about it.
