check engine light
Thanks Jim
These are a few things to check.
Thanks Jim
R1 DIAGNOSTIC TROUBLE CODE (DTC) P0381
- DTC P0381 is set when the PCM detects a malfunction in the glow plug warning lamp circuit.
- Possible causes:
- Open/grounded circuit
- Open WAIT TO START light
- Open fuse (F-Series — Fuse 17, Econoline — Fuse 18)
- Start engine.
- Key on, engine running.
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to R2 . </TD><TD width="50%">GO to R3 . </TD></TR></TBODY></TABLE>
R2 CHECK CIRCUIT 464 (BK/PK) FOR SHORT
- Key off.
- Disconnect PCM.
- Key on, engine off.
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">SERVICE ground short in Circuit 464 (BK/PK) between WAIT TO START light and PCM. RERUN Scan Tool Diagnostic Test. </TD><TD width="50%">REPLACE PCM. RERUN Scan Tool Diagnostic Test. </TD></TR></TBODY></TABLE>
R3 CHECK INTERMITTENT P0381
- A Continuous DTC P0381 is set when the PCM detects a malfunction in the WAIT TO START light circuit.
- Possible causes:
- intermittently open/grounded circuit or fuse.
- intermittently open WAIT TO START light
- Key off.
- Key on.
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">Concern is intermittent. GO to R9 . </TD><TD width="50%">GO to R4 . </TD></TR></TBODY></TABLE>
R4 CHECK FUSE FOR OPEN
- Key off.
- Check fuse (F-Series — Fuse 17, Econoline — Fuse 18) for continuity.
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to R5 . </TD><TD width="50%">GO to R6 . </TD></TR></TBODY></TABLE>
R5 CHECK WARNING LIGHT BULB FOR OPEN
- Disconnect WAIT TO START light.
- Check bulb for continuity.
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to R7 . </TD><TD width="50%">REPLACE bulb. RERUN Scan Tool Diagnostic Test. </TD></TR></TBODY></TABLE>
R6 CHECK CIRCUIT 640 (R/Y) FOR GROUND SHORT
- Measure resistance between Circuit 640 (R/Y) and chassis ground.
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">REPLACE fuse. RERUN Scan Tool Diagnostic Test. </TD><TD width="50%">SERVICE ground short in Circuit 640 (R/Y). REPLACE fuse. RERUN Scan Tool Diagnostic Test. </TD></TR></TBODY></TABLE>
R7 CHECK FOR OPEN CIRCUIT 640 (R/Y)
- Key off.
- Measure voltage on Circuit 640 (R/Y) at warning light harness connector.
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to R8 . </TD><TD width="50%">SERVICE open in Circuit 640 (R/Y) between fuse and WAIT TO START light. RERUN Scan Tool Diagnostic Test. </TD></TR></TBODY></TABLE>
R8 CHECK FOR OPEN IN CIRCUIT 464 (BK/PK)
- Disconnect PCM.
- Install breakout box.
- Measure resistance in Circuit 464 (BK/PK) between the WAIT TO START light and Pin 80 (49 State except Econoline) or Pin 70 (California and all Econoline) on the breakout box.
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">REPLACE PCM. RERUN Scan Tool Diagnostic Test. </TD><TD width="50%">SERVICE open in Circuit 464 (BK/PK). RERUN Scan Tool Diagnostic Test. </TD></TR></TBODY></TABLE>
R9 CONTINUOUS P0381 CODE
- Clear Continuous DTC P0381.
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to R10 . </TD><TD width="50%">Code was not cleared after a previous repair. </TD></TR></TBODY></TABLE>
R10 CHECK FOR CODE P0381 AFTER ROAD TEST
Did the WAIT TO START light come on or flicker on and off during road test?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">SERVICE Circuit 464 (BK/PK) intermittently shorting to ground. </TD><TD width="50%">GO to R11 . </TD></TR></TBODY></TABLE>
R11 CHECK FOR INTERMITTENTLY OPEN CIRCUIT
- Install breakout box. Leave PCM disconnected.
- Inspect PCM connector for loose or backing out pins.
- Ground test Pin 80 (49 State except Econoline) or test Pin 70 (California and all Econoline).
- Tap on dashboard. Shake harness under dash and under hood between the 76-way connector and PCM connector.
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">SERVICE an intermittently open light bulb or circuit between fuse and PCM connector. </TD><TD width="50%">If unable to find an intermittent short or open, REPLACE PCM. </TD></TR></TBODY></TABLE>
<HR>
here
- Possible causes:
- Key off.
- Key on.
- Key off.
- Key off.
- Disconnect PCM.
<HR>
there are many gurues (sp?) like Rick. I tried to send rep points to you Rick ,but you know the story.
thanks for all the help guys.
Next time these symptoms come up I 'll ask ..."do you have a fish on your ball?"
and you are ACTION X 4478 = ACTION4478. LOL.
