broken tilt stearing
Old Mar 28, 2015 | 05:49 PM
killfrosty's Avatar
killfrosty
93 f250 XLT 7.3 liter 4 wheel drive extended cab long bed 5 speed.
A while back my tilt steering broke. not the adjustment part but the piece that holds the steering shaft in the center. my question is would it be easier to replace the whole steering column or to try to dig into the steering wheel and replace that bearing?
Old Mar 28, 2015 | 07:22 PM
redford's Avatar
redford
FTE Leadership Emeritus
Thread moved to correct forum.
Old Mar 28, 2015 | 07:24 PM
killfrosty's Avatar
killfrosty
Thanks. I'm still trying to figure out this forum
Old Mar 29, 2015 | 07:26 AM
tjc transport's Avatar
tjc transport
i ain't rite
i would just replace the column.
Old Mar 31, 2015 | 01:49 PM
killfrosty's Avatar
killfrosty
I'm afraid if I disconnect it from my power steering unit my power steering and it will fall apart. Lol would that seriously be easier than just taking the steering wheel off and getting to that bearing?
Old Mar 31, 2015 | 05:56 PM
tjc transport
i ain't rite
you do not touch the steering box. it is connected under the dash and then you have the connector shaft that goes down to the box. you can probably pick up a good column for $50.
it will most likely cost you over $100 to rebuild the column.
Old Mar 31, 2015 | 09:21 PM
killfrosty's Avatar
killfrosty
thanks for the info I just looked up online a diagram for my steering column you're absolutely right about not touching the column itself. I'll look around see if I can find a tilt box thanks again
abyars111
Nov 15, 2013 10:09 PM
Scratcher
Nov 28, 2010 08:58 PM
big64
Jun 15, 2009 08:41 AM
Buzzerooni
Apr 20, 2007 06:07 PM
timjk69
Dec 2, 2006 01:01 PM
