steering wheel to column gap
Old Nov 15, 2013 | 11:08 AM
abyars111's Avatar
abyars111
I have a 1970 F250 2wd. I have replaced the Ford steering box with a Red Head unit. I have installed a new rubber coupler. I have replaced the shift collar and upper bearing. My steering wheel has about a 1/4" gap between it and the steering column, it's been this way since I bought the truck. I'd like to fix this. I've seen in the shop manual a procedure for adjusting this. Loosen the column and slide it up. I tried and mine would not budge. Has anyone had to do this?
Old Nov 15, 2013 | 11:56 AM
HIO Silver's Avatar
HIO Silver
There's a clamp on the firewall plate (engine compartment side) that needs to be loosened. Also loosen the clamp securing the column tube under the dash.
Now push down on the steering wheel & shaft while pulling up on the column tube to achieve a 1/8-inch gap.
Be mindful to not distort the rag joint as to cause undue stress on it.
Old Nov 15, 2013 | 01:07 PM
abyars111's Avatar
abyars111
I didn't try pushing down on the steering wheel while pulling up on the column. That would be my problem.
Thanks, HIO!
Old Nov 15, 2013 | 04:01 PM
JEFFFAFA's Avatar
JEFFFAFA
Sounds like it has the wrong steering wheel on it.
Old Nov 15, 2013 | 04:30 PM
abyars111's Avatar
abyars111
it's the original '70 wheel
Old Nov 15, 2013 | 05:53 PM
JEFFFAFA's Avatar
JEFFFAFA
Is it the original column then?
Old Nov 15, 2013 | 10:09 PM
abyars111's Avatar
abyars111
yes, sir, I should have mentioned that
Fordication
Dec 27, 2016 11:30 PM
mhu
May 8, 2015 06:14 AM
Scratcher
Nov 28, 2010 08:58 PM
big64
Jun 15, 2009 08:41 AM
Seifferlein
Jul 20, 2004 10:22 AM
