steering column
Old Jun 14, 2009 | 06:05 PM
big64's Avatar
big64
steering column
the reason i am thinking of replacing the steering column on my 88f250 is the steering wheel has a lot of play in it both up and down and side to side .i pulled the steering wheel ,the bearings looked good .i guess the whole column is worn out unless i"m missing something.
Old Jun 14, 2009 | 11:27 PM
Sycostang67's Avatar
Sycostang67
It could be internally damaged, when people use the steering wheel to pull themselves into the truck, it falls apart.
Old Jun 15, 2009 | 08:41 AM
alxsnmr's Avatar
alxsnmr
Did you move the shaft with the wheel out of the way to see where the play was coming from? Like Sycostang said the column falls apart when people use it as a grab handle, the column has alot of cast metal in it that breaks easily.
