2000 B3000 4x4 non shift
Old Mar 26, 2015 | 09:04 AM
wburge's Avatar
wburge
Ok Guys, I have spent two days searching for a fix to a problem like mine on my truck and I haven't quite found it. Sooo, here it is. I have a 2000 Mazda B3000 4x4. I'm getting the dreaded six lights flashing. I can hear the clicking under the dash as it attempts to engage the 4WD. I have checked the Motor at the T/C and no power. What feeds voltage to the motor its self? and is there any other thing I can check B-4 having it scanned? oh and it is a manual tranny.
Old Mar 27, 2015 | 08:35 AM
pawpaw's Avatar
pawpaw
You'll likely need to use a scantool like a ELM327, running software like FORScan, ect, that can access the GEM for codes & display them on your viewing device, then post All code clue Numbers found.
Old Mar 30, 2015 | 09:38 AM
wburge's Avatar
wburge
Well,this is what I have found. I removed the motor and took it arapart and discovered that the magnets inside aree loose and broken. not sure if this is THE problem but it is a problem. All of the replacement motors i have foundhave only 7 pins and mine has 8 anyone have any feed back on that. thanks..
Old Mar 30, 2015 | 11:43 AM
Rockledge's Avatar
Rockledge
All of the replacement motors i have foundhave only 7 pins and mine has 8..
How many wires are there to the connector?
The Ford wiring diagram for the 2000 Ranger transfer case motor shows a 7-pin harness connector corresponding to 7 wires. It also shows a few other unused pins in the connector.
Old Mar 30, 2015 | 11:54 AM
wburge's Avatar
wburge
it has 7 in theactual motor, but there is a black wire that comes out of the rear of the transfer case near where the u-joint hooks up that goes into the harness too.
Red Ex
Jan 21, 2012 03:39 PM
imabaka
Jul 26, 2010 09:01 PM
jaitken
Nov 21, 2009 07:26 PM
boatcop1
Jul 8, 2005 09:29 AM
findr
Feb 13, 2004 06:01 AM
