AC Compressor Clutch
Old Mar 26, 2015 | 07:29 AM
twm011's Avatar
twm011
When i purchased my e99 7.3 I realized that it had a bad motor and the ac lines where taken apart. I swapped the motor with another one I knew ran with a good AC. However, after the swap the compressor will not engage. It is not getting power to it. I jumped the compressor from the battery and it worked fine. The clutch engaged, it took the freon just fine, and the AC blew cold. I just can't seem to figure out why its not getting power. Any suggestions?
Old Mar 26, 2015 | 08:05 AM
mueckster's Avatar
mueckster
Have you checked the connections at the high pressure switch at the line from the compressor? The switch there is known to have connectivity issues in the terminals. Usually solved with a new switch. Check for power at the wires and try wiggling the connection.
Old Mar 26, 2015 | 08:51 AM
twm011's Avatar
twm011
As far as I can tell there is no power going to the wires?
Old Mar 26, 2015 | 09:29 AM
mueckster's Avatar
mueckster
Do you "not" have power at the low pressure switch at the Accumulator/Drier, as well? The pressure switches are wired in "series" and must go thru it before the high pressure switch, then on to the a/c clutch. Are the other functions of the a/c control working normally?
Old Mar 26, 2015 | 11:04 AM
twm011's Avatar
twm011
There was a poor connection on the low pressure switch. The ac works fine now. Thank you!!
aaron8669
Large Truck
May 2, 2018 08:06 AM
dragford
19
Sep 16, 2010 06:45 AM
norrislaketn
Aug 24, 2003 10:21 AM
wardenj
1978 - 1996 Big Bronco
Aug 11, 2002 11:10 PM
cmosis5
Feb 1, 2002 04:23 PM
