AC Compressor Cycling 91 f150
Old Aug 21, 2003 | 06:46 AM
norrislaketn's Avatar
norrislaketn
The ac compressor is cycling on and off approximately every 30 seconds. The system has been converted to 134. I am on the 5th compressor, 3 clutch and replaced the condensor due to trash from the last compressor plugging it up. The orifice has been changed.
Any thoughts?
Old Aug 22, 2003 | 07:24 PM
mantta's Avatar
mantta
It sounds like you are low on refrigerant and the low pressure switch is cycling it on and off.
Old Aug 23, 2003 | 05:10 PM
norrislaketn
I have check the pressue and it is within specs. Any other thoughts? Is there a switch somewhere that controlls the cycle?
Old Aug 23, 2003 | 05:22 PM
mantta's Avatar
mantta
Yes, there is a low pressure cutout switch that cuts out your magnetic clutch when the low side pressure drops to around 20 psi. It is usually mounted on the suction accumulator. It cuts back in around 40 psi. If your system is low on refrigerant it will cycle the clutch continously.
Old Aug 23, 2003 | 05:25 PM
norrislaketn
It looks like a cheap item to replace, I'll give it a try, Thanks
Old Aug 24, 2003 | 10:21 AM
norrislaketn
I replaced the switch and all is well, Thanks for your help....
TheDuke
Jun 6, 2016 12:13 PM
2Fords1Jeep
1997 - 2003 F150
Aug 25, 2014 09:40 PM
jeff gammon
Aug 4, 2009 11:56 PM
T_Moss
Apr 25, 2006 07:29 PM
knggordon
Aug 16, 2003 08:58 AM
