D60 SWITCH
Old Mar 23, 2015 | 07:18 PM
PlumCrazy7's Avatar
PlumCrazy7
D60 SWITCH
Hello, I am doing a non-typical D60 swap. I am putting a D60 into the F250 from my sig off of a 1990 complete donor F350. What's different is I want to put my TTB D44 into the donor F350.
Is there a way to transfer the riveted crossmember to axle support for the TTB to the 350?
Old Mar 23, 2015 | 08:04 PM
Nothing Special's Avatar
Nothing Special
Someone did that on this board a year or so ago. I forget who it was, but if you search enough you ought to be able to find it. As I recall it was a pretty straightforward swap both ways and he went from two running trucks to two running trucks in a weekend.
Old Mar 23, 2015 | 08:32 PM
Diesel_Brad's Avatar
Diesel_Brad
the TTB axle pivot brackets are Bolted in, not riveted
Old Mar 24, 2015 | 12:39 AM
firegod75's Avatar
firegod75
Me and My brother did that kind of swap a few months ago all in a weekend. My brother took the D60 out of my 89 f350 and put it in his 97 f250. I took his ttb and put it in my truck along with the blocks and springs from his truck. I also got his rims and tires.
Old Mar 24, 2015 | 08:49 AM
tjc transport's Avatar
tjc transport
i ain't rite
the crossmember is part of the truck frame, and is the same on both vehicles. the drop bracket for the TTB bolts in the same place as the drop bracket for the trac bar.
simply unbolt and swap the drop brackets. they asre held on by 3 5/8 bolts if i remember the size correctly.
Old Mar 24, 2015 | 01:25 PM
PlumCrazy7's Avatar
PlumCrazy7
Thanks for all the replies. Just to clarify, in the forum write-up article for the swap he ground off the protruding bracket in the middle because it was riveted. I'll crawl under and check on the 250, D60 is already pulled so it's easy to look at the 350.
This is what he says in the article: Once the old IFS axle is removed you’ll
have to remove the cross member to axle brackets to make room for the Dana
60. There were two brackets which unbolted and came off with no problems.
A third, on the drivers side, is riveted and bolted to the frame near the
engine mount. It also appears to provide structural support to the
engine mount. You may wish to grind down the rivets and remove the
bracket altogether, however we felt it best to leave it in place and grind
down the part that would interfere with the Dana 60, see the following
pictures. But if you do this you can’t go back, so understand the
consequences before getting out the grinder.
This is after grinding, is this just the track bar stuff?
Old Mar 24, 2015 | 01:27 PM
tjc transport
i ain't rite
is that a F150 frame???
never saw anything like that on the F250/F350 frame.
Old Mar 24, 2015 | 05:01 PM
PlumCrazy7's Avatar
PlumCrazy7
It is supposed to be for 1986-1996 F250s, here Dana 60 Conversion for F250 years 1986-1996 - Ford Trucks
I take it I don't need to worry about it?
Old Mar 24, 2015 | 05:29 PM
tjc transport
i ain't rite
no idea what he is talking about, all of my trucks have a good 8 -12 inches between the axle and the crossmember.
Old Mar 24, 2015 | 07:06 PM
PlumCrazy7's Avatar
PlumCrazy7
Well that is nice to know, thanks for clearing that up!
Where do you guys order rebuild parts from? I've priced out East Coast Gear to about $600 shipped with both outer and the differential rebuild kits. Any other suggestions?
Old Mar 25, 2015 | 06:37 AM
tjc transport
i ain't rite
the last rebuild i did was close to 15 years ago, and i got everything to redo the diff for $300 from a local speed shop, including gear set and kingpins.
Old Mar 25, 2015 | 11:10 AM
1993_f350_2013's Avatar
1993_f350_2013
Here's the swap I believe you're talking about
The user was blue rebel
https://www.ford-trucks.com/forums/1290433-89-f250-dana-60-swap-93-f350-dana-50-swap.html
Old Mar 25, 2015 | 06:09 PM
Pkupman82's Avatar
Pkupman82
No need to swap cross members. They're all pretty much the same. I changed my 84 F250 over to a D60. Pretty much a direct bolt on, only had to drill two holes for the track bar bracket. But 80-84 F350s didn't have a solid axle, so the cross members were not drilled yet. I am 95% sure all F250s and 350s from 1985-1997 had all the holes drilled in the cross members. So on newer models, a TTB to Monobeam swap was a bolt on affair.
Old Apr 4, 2015 | 11:16 AM
PlumCrazy7's Avatar
PlumCrazy7
I'm having trouble figuring out what model number u-joint I need. I know to use greaseable Spicers, my options are: 1310 / 5-1310X, 1350 / 5-1350X, 1410 / 5-1410X, 1480 / SPL55X, and 5-733x / SPL55-4X. Just wondering which models you guys use for axleshafts and driveshafts. Thanks
Old Apr 4, 2015 | 12:02 PM
tjc transport
i ain't rite
for my 1988, i go to napa and tell them i want universals for an 88 F350. they give me the proper parts every time.
just ask for the universals for the year axle you have.
mustanginca
Jan 29, 2011 07:17 PM
joshg97250
Dec 14, 2010 01:18 PM
blacklab1
May 4, 2010 06:39 PM
MASSIVE460
Feb 1, 2008 12:39 AM
rustyolred27
Apr 8, 2007 12:33 PM
