Brass or steel
Old Mar 22, 2015 | 01:01 PM
skidoorulz's Avatar
skidoorulz
Brass or steel
I need to replace the cam plug in my 292 as it looks like it is crooked and seeping oil. (Machine shop installed) I can get both brass and steel plug. Which would you use and why. Also should I use any sealant on it
Old Mar 22, 2015 | 02:12 PM
arctic y block's Avatar
arctic y block
If your in a dry climate than steel is fine. Brass is softer and
easier to damage when installing but salt don't bother it as much.
Old Mar 23, 2015 | 11:31 AM
skidoorulz's Avatar
skidoorulz
Only one thought on this? How about a sealer? Any thoughts on that?
Old Mar 23, 2015 | 12:08 PM
banjopicker66's Avatar
banjopicker66
No need for a sealer.
The plugs are slightly oversized. This allows the soft metal (either brass or steel) to conform to the slight irregularities in the cast iron as it is forced into the opening, and so seal it.
Old Mar 23, 2015 | 12:24 PM
daveengelson's Avatar
daveengelson
Suggest going with steel, not familiar with 'brass' plug but have had bad experience w/ brass components which I found tend to develop cracks due to engine vibration.
Old Mar 23, 2015 | 05:07 PM
skidoorulz's Avatar
skidoorulz
OK everyone thanks. Picked up a steel one today
Old Mar 23, 2015 | 08:40 PM
1972RedNeck's Avatar
1972RedNeck
If you haven't installed it yet, I like to clean the hole with emery cloth and then smear a coat of hi-tack around the hole before installing the plug. Maybe it is more than necessary but I have never had one leak yet.
broozer
Jul 24, 2013 01:23 AM
thebarnyard13
Jul 29, 2010 03:41 PM
Fordgery
Jan 3, 2010 11:41 PM
ford390gashog
Feb 8, 2006 09:30 AM
crawlfish
Dec 4, 2004 04:54 PM
