cam plug?
Old Feb 8, 2006 | 12:32 AM
ford390gashog's Avatar
ford390gashog
cam plug?
well i need some help with the cam plug on the back of the block. i know it goes in backwards right? but do you install the plug from inside the block or from the outside?
Old Feb 8, 2006 | 12:44 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
From the outside, after it's installed clean real good with lacquar thinner or brake Klean on a damp rag then smear RTV around the joint. We don't want more oil leaks just the valve covers.
.....=o&o>.....
Old Feb 8, 2006 | 12:48 AM
ford390gashog
ok,
just looks like it won't go in right. the cam plug has a slight taper which makes it a tiny bit larger than the cam plug hole. i will give it a shot.
Old Feb 8, 2006 | 04:51 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Yes it goes in backwards. I use RTV also as Carl mentioned. Also check your oil galley plugs for seepage. The press in's seep like crazy. The threaded ones are better. Every block I've taken out that had the press in galley plugs have shown they leaked.
G.
Old Feb 8, 2006 | 09:30 AM
Redmanbob's Avatar
Redmanbob
Chamfer the plug, and I could have sworn the book mentioned moly grease to ease it in..would have to read it again.
