Sponsored by: Auxito
Power door locks
Old Mar 21, 2015 | 10:07 AM
rob8210's Avatar
rob8210
Power door locks
I have a 2002 f150 supercrew, 4wd. The power door locks stopped working the other day and I am pulling my hair out ( at least the grey hair) trying to fix it. So far I have checked the fuse in the power distribution box, good. I have checked the wires from the doors to the cab along the door sills to the rear doors , all good. I did find a couple of iffy grounds on the left kick panel and cleaned and repaired them. I am having a heck of a time finding the group of relays that control the lock and unlock functions. Remember , I have no power lock function at all. I would swear its not getting power to the relays but until I find them , I just don't know. Anybody here know where they are supposed to be?
Old Mar 22, 2015 | 02:16 AM
Bluegrass 7's Avatar
Bluegrass 7
If they all fail, they are not getting power to operate.
The up and down switches just reverses the applied polarity to the DC motors.
Be sure you looked at the correct fuse.
Good luck.
Old Mar 22, 2015 | 07:39 AM
projectSHO89's Avatar
projectSHO89
The door locks are controlled by the Central Security Module (CSM), they are not directly controlled by the switches (which are inputs to the CSM).
Old Mar 30, 2015 | 12:35 PM
Motorcityiron's Avatar
Motorcityiron
I have a similar truck with the same problem.
What is the fix for this?
Thanks so much,
Jake
Old Aug 14, 2015 | 05:55 AM
rob8210's Avatar
rob8210
Well fellas I did finally figure it out , no power coming into the CSM.
Old Aug 14, 2015 | 11:32 AM
steve(ill)'s Avatar
steve(ill)
where did the power problem originate ? fuse ? bad wire ?
Valzan
Electrical Systems/Wiring
Dec 9, 2012 04:35 PM
Jet Jockey
1997 - 2003 F150
15
Nov 12, 2008 05:56 AM
00Explorer00
Aug 24, 2007 10:23 AM
azlincolnmercury
Jan 16, 2007 10:29 PM
ChrisAdams
2004 - 2008 F150
29
Jan 28, 2005 08:46 PM
