Sponsored by: Auxito
trans swap
Old Aug 3, 2014 | 10:04 AM
tnvolsfootball's Avatar
tnvolsfootball
trans swap
I took a 4R70w trans out of a 1998 F150 4x4 with a 4.6 , I put it in a 2003 F150 4x4 with a 5.4 that had the same trans now truck will not shift. trans worked great before swapping can anyone help with my problem thanks
Old Oct 19, 2014 | 01:17 PM
Fordfreak_24's Avatar
Fordfreak_24
The trannies are the same but the electronic is different. I know you have to repin the wiring harness. I'm going threw the same swap but cant find a write up on it anywhere
Old Jul 9, 2015 | 11:15 AM
tylersales's Avatar
tylersales
I gotta 97 Ford F 150 2wd and can only find 2wd F150 with the 5.4 is this the same tranny ??
Old Jul 9, 2015 | 12:07 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
So you're asking if a 2wd F-150 would be the same as a 2wd F-150? That's a pretty silly question.
Now if you told us the year and engine of BOTH vehicles then we MIGHT be able to help you.
Old Jul 10, 2015 | 01:28 AM
brokenleg's Avatar
brokenleg
been my experience that with Ford to stay within 2 years......Ford likes to change every 2 years....for example on a 1997, 98 should work, but 99 has a lot of different stuff....
Old Jul 10, 2015 | 12:09 PM
tylersales's Avatar
tylersales
yes they are both 97s one has a 5.4 and the other has a 4.6 but the 5.4 has a button on the shifter for od and the 4.6 doesnt
Old Jul 10, 2015 | 01:48 PM
Mark Kovalsky
The both should have the button on the shifter.
If you have both trucks take a look at the data tag in the driver's door opening. There is a TR shown, and under that either a U or an E. If the same letter is on both trucks the trans should work fine.
Old Aug 14, 2015 | 10:24 PM
miname's Avatar
miname
miname
I have 1997 4.2 v6 automatic with a bad trans. I also have a 1998 5.4v8 with a good automatic transmission. Both have the letter "U" on the data tag on the drivers door post. Will the v8 trans work in the v6 truck?
Old Aug 15, 2015 | 08:20 AM
Mark Kovalsky
No, it will not. The 4.2L and 5.4L have different bolt patterns. While they are both 4R70W transmissions, they will not interchange.
kyfordf150
Sep 6, 2010 11:36 PM
miked79928
Apr 18, 2010 10:52 PM
tcurry
Apr 30, 2003 11:40 PM
