I have a 1986 F150 that I am wanting to do an auto to manual transmission swap. I have everything I need Im just trying to figure out how to do a clutch pedal. The transmission is out of a 96 and the engine is a 302. I have a pedal assembly from a 96 but it does not look like it is going to fit. Also there is no hole in the fire wall on my truck where the clutch master cylinder goes through. Im thinking I can either build my own custom assembly or find an aftermarket one to make work. I am capable of fabricating anything as I can weld and grind.
Just go to the junkyard and get a pedal assembly from a 86-down truck. It will bolt right in and work, no fabbing needed. If you look real close on the pass side of the brake booster area, you should see some dimples where the holes need to be drilled for the clutch master.
Thread revival: are the brake and clutch pedals one unit or seperate when timing them? I am adding this to my jy list for an April run. I think the Gary Lewis ZF swap is next for beast.
Derrick- did you grab the inspection cover, aka trans hump, when you got the transmission ?
I swapped the whole thing. Can you mix and match parts to make one, I am not sure. I think I remmeber the problem being the bushings for the clutch pedal don't exist in the auto assembly.
I did not pull the trans from a yard so I did not get the inspection cover. I was hoping to find one of those as well. Im on the hunt for a yard with the pedal assembly I need
I looked up a 86 ford 150 with a 4 speed 4x4 new process tranny in Texas. I figured if they had a 4 speed truck they might have the truck with the clutch pedals sitting around. This is what came up.
1985
Transmission
Ford Bronco Full Size E3TA-VA 154,000 A 3106 $350.04 B & M Cars & Salvage USA-TX(Sulphur-Springs) Request_Quote 1-866-439-0228 Request_Insurance_Quote
1985
Transmission
Ford Bronco Full Size C 1575 $300 Eagle Mountain Auto Salvage USA-TX(Ft.-Worth) Request_Quote 817-237-3350 Request_Insurance_Quote
1987
Transmission
Ford Truck F150 M.T., (4 spd), New Process 435, 4x4,VERIFY IN TEAR DOWN 380,000 C 4354 $250.04 B & M Cars & Salvage USA-TX(Sulphur-Springs) Request_Quote 1-866-439-0228 Request_Insurance_Quote
1978
Transmission
Ford Truck 150 5.8L 6I0034 $250 Eckert & Sons Auto Parts USA-TX(Stonewall) E-mail 1-800-950-8014
1977
Transmission
Ford Truck F150 08L008 $150 G & N Auto Salvage LLC USA-TX(El-Paso) Request_Quote 915-877-5353 Request_Insurance_Quote
1984
Transmission
Ford Truck F150 4SP,4.9L,5-84,NTC,E3TA7003VA J01220 $Call Burnet Auto Salvage KOLT USA-TX(Burnet) E-mail 1-800-375-6340
1978
Transmission
Ford Truck F250 4MT 4X4 NP435 F250 31 SPLINE ,STOCK NO. #CW60921 #CW60921 $Call Big Four Auto Parts USA-TX(Austin) Request_Quote 1-800-445-3404 Request_Insurance_Quote
1984
Transmission
Ford Truck 250 E3TA-VA P14040 $Call Dulaney Auto USA-TX(Plainview) E-mail 800-858-4190 / 806-296-7456
I then picked a warner 4 speed 4x4 tranny. Here's what came up.
1986
Transmission
Ford Bronco 4X4,STOCK NO. #2967 78,425 A #2967 $450 Smith Auto Salvage USA-TX(Jacksonville) E-mail 1-903-586-8346 / 1-877-485-5255
1986
Transmission
Ford Truck F250 4SPD MT, ,Wrner, T-18, 4X4-183K 183,000 A 9B96 $375 K & K Motors, Inc. USA-TX(Graham) Request_Quote 1-800-766-2009 Request_Insurance_Quote
1985
Transmission
Ford Truck F350 4 X 4,4 SPD. NOF $200 Brothers Auto Parts USA-TX(San-Antonio) Request_Quote 1-800-926-8591 Request_Insurance_Quote
I didn't even try the 2wd trannies, but that would work also. Just go to www,car-part.com.
