Sponsored by: Real Truck
Connecting to trailer lights
Old Mar 20, 2015 | 11:57 AM
ligito's Avatar
ligito
I am going to install a cab rack.
I am going to install Stop/Tail/Turn lights on the cab rack.
I will be using a 7 pole junction box under the bed.
The existing 7 pole blade trailer socket also has a cable attached 4 flat connector.
Is there a product that will mount inline, between the factory connectors?
Or, at the front of the cab, where the trailer harness plugs in.
Maybe something like the Hopkins 40157? Endurance? Ford
Old Mar 20, 2015 | 03:14 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Looks like it would work. I used something similar:
https://www.etrailer.com/Custom-Fit-...893-11932.html
I put a 7-pin in the bed for the gooseneck hitch, then piggybacked the rack wiring off the second plug's wires. Use waterproof or adhesive-lined heat shrink to protect the wiring, and solder instead of using crimps and it should hold up fine.
Old Mar 20, 2015 | 03:30 PM
ligito's Avatar
ligito
My truck also has a 7-pin in the bed for the gooseneck hitch.
Old Mar 20, 2015 | 03:31 PM
ligito's Avatar
ligito
Shouldn't I add some fuses, somewhere?
Old Mar 20, 2015 | 06:32 PM
phredE's Avatar
phredE
Your truck should already have relays and fuses for the 7 pin trailer connector. Look in the owners manual and it should show you where they are located.
Old Mar 20, 2015 | 07:51 PM
Just Strokin's Avatar
Just Strokin
since you have the 7pin in the bred....what about an extension cord?
http://www.ebay.com/itm/7-Way-to-7-Way-RV-TRAILER-EXTENSION-CORD-8-10110-096EX-/251562420985?pt=Motors_RV_Trailer_Camper_Parts_Accessories&hash=item3a9249eaf9&vxp=mtr
Old Mar 21, 2015 | 11:45 AM
ligito's Avatar
ligito
7 Way to 7 Way RV Trailer Extension Cord 8' 10110 096EX | eBay
I'm afraid that would get in the way, when hauling dirt etc.
I may be able to connect to those same wires, underneath the bed.
That would be at the front, where I need it.
Caddison
Feb 9, 2015 04:19 AM
redz284u
Dec 4, 2014 04:49 AM
ToaDisco
Nov 28, 2009 09:49 PM
02f250fx4
All Things Towing
Dec 3, 2007 05:04 PM
blackbear
May 31, 2003 01:35 AM
