I hear you - I like my V10 also - it may not be piston slap. My 99 did however sound like a lifter or you could also construe it to sound like the lifters hadn't pumped up yet on initial start (oil pressure not up). It was a surface noise (not a deep down noise like a road knock). Didn't last long (15 seconds) and didn't happen again all day once the truck was warmed up
The cure was no cure - tried everything - it still happened. Went the dealership route - no way they would replace an engine on a four year old truck - told me the slap was normal, just a loose engine and would run forever. They did tell me they would put it in writing that if the engine ever failed due to piston slap they would repair it free of charge and they doubled that coverage to cover the motor until 120,000 (for slap issues only however)
If it's slap dont worry - I guess thats the issue I'm putting forward. For anyone else in their warranty period, start documenting it.
I have a 1992 Dodge Caravan with the 3.3L that does the same thing. I read a service bulletin that addressed the issue and it said that basically the engines were built with loose tolerances for increased economy ( fuel efficiency) and that it was a benign condition.
I also had a '90 S10 that had a louder 'knock' that was worse and lasted longer the colder it was. When it was warm, I couldn't really hear it. Turns out that engine was too 'loose' and it was replaced under warranty.
It seems that the latest practice in engine building is to build them loosely to be more efficient. It seems like this would contribute to a short service life, but maybe the improvements in metalurgy and oil formulation make up some of the difference.
Originally posted by vze2372e I hear you - I like my V10 also - it may not be piston slap. My 99 did however sound like a lifter or you could also construe it to sound like the lifters hadn't pumped up yet on initial start (oil pressure not up). It was a surface noise (not a deep down noise like a road knock). Didn't last long (15 seconds) and didn't happen again all day once the truck was warmed up
Mike
I've been a member here since Jan 2000, and I found FTE by looking for info on my engine noise, and have been here ever since. I bot my truck from Budget rent-a-car. They used it as a shuttle bus when they had to drive to say Seattle from Portland to retrieve one way rentals. It had a complete service history including the replacing of the front passenger side fender due to a minor fender bender. And there was notation of the noise, and the dealers response. Whether that would be enough for a post-warranty warranty claim I dunno, I highly doubt it. But the good folks here at FTE gave me all the info I could possibly use, so I don't stress out over it. I know it's gonna happen, I use really good oil and Motorcraft filters. It idles until oil is thoroughly distributed throughout my engine. Although I have another small issue, which I will post here later, take care.
Okay, I've read tons and tons on this phenomenon called "piston slap" that we V10 owners seem to experience. My truck has it, two of my friends trucks have it. My question is, does this problem really do any REAL damage? Any documented cases of failures that can be traced back to piston slap? I've got 139,000 on my truck now, and it gets worked pretty hard at times, and I have had no problems at all. The noise is no worse now than it ever was, and lasts about 8 seconds on initial startup, and then I dont ever hear it again until the next day. Some days I dont hear it at all. I run Mobil 1 5W30 synthetic, changed every 3000 miles, and Motorcraft anti drainback filters, so there are no oil issues there. Since I have heard of no failures related to piston slap, I have to wonder if it is just more of an inconvenience or annoyance than it is a problem. Just my two cents worth though.
Originally posted by airtractrdrivr Okay, I've read tons and tons on this phenomenon called "piston slap" that we V10 owners seem to experience. My truck has it, two of my friends trucks have it. My question is, does this problem really do any REAL damage? Any documented cases of failures that can be traced back to piston slap? I've got 139,000 on my truck now, and it gets worked pretty hard at times, and I have had no problems at all. The noise is no worse now than it ever was, and lasts about 8 seconds on initial startup, and then I dont ever hear it again until the next day. Some days I dont hear it at all. I run Mobil 1 5W30 synthetic, changed every 3000 miles, and Motorcraft anti drainback filters, so there are no oil issues there. Since I have heard of no failures related to piston slap, I have to wonder if it is just more of an inconvenience or annoyance than it is a problem. Just my two cents worth though.
So, how much of a difference on the "seat of the pants dyno" did the Diablo chip make ? Right after I bot my V-10 I got injured and have been struggling ever since with lawyers and Dr's and what not. But I've always wanted to chip my van. I almost bot the Kenne Bell switch chip one time until I decided to go with the Diablo chip because it helped support this site, and I liked coming here. But now I'm semi back to work and hope to be full time here real soon so now I'm dreaming of more HP/more torque (don't we all?). Would you do it again in a second type thing ? Or would you do something else ? With premium now $1.80 a gallon from $1.30 when I first bot my V-10 are you as happy with it or would you go back to less HP and regular, $1.50 a gallon gasoline ?
I love my Diablo chip. I could definitely feel the difference when I put it in. Feels stronger throughout all areas of the power curve, PLUS got rid of that pesky speed limiter. As far as whether or not I would do it again with the economy like it is now, my answer is "probably so". I run 89 octane fuel with no problems, and where I live, it is only $1.58, so it's not too bad yet. I ran 91 octane when i first put in the chip, but one day I had to fill up and the 91 side of the pumps were all shut down. Took a chance and filled up with the 89, and it worked fine, so I've been using it ever since. But, with some other mods I am thinking of doing, IF I go ahead with them, I am probably going to have to switch over to a dual program chip like the Kenne Bell or the one that Diablo makes. But yeah, I would do it all basically the same again! It's too much fun not to!
