Sponsored by: Real Truck
Super Duty backfire on startup
Old Sep 5, 2015 | 06:45 PM
stowbilly96's Avatar
stowbilly96
Started my truck this morning. 2000 F350, V10, 153000 on the clock. Immediately sounded like a shotgun went off under the hood, now it sounds like it's running a cutoff exhaust. Had a tiny manifold tick prior to this, but can it backfire hard enough to crack/destroy the manifold?
Old Sep 5, 2015 | 06:49 PM
JWC 3's Avatar
JWC 3
Sure you did not blow a spark plug?
Old Sep 5, 2015 | 06:51 PM
MisterCMK's Avatar
MisterCMK
Definitely sounds like you blew a spark plug
Old Sep 5, 2015 | 08:22 PM
stowbilly96
Yes I did. The 8th plug blew out, but the spark plug threads back in? What should I do?
Old Sep 5, 2015 | 08:38 PM
MisterCMK's Avatar
MisterCMK
Put a timesert insert into the head
Old Sep 5, 2015 | 09:20 PM
stowbilly96
Well I checked threads on the head, they were good. Checked spark plug, it was good. The coil pack exploded apart though. I torqued the spark plug down to 11 inch pounds like my Haynes Manual said, didn't bolt the pack back down in case it did it again and started it up. Nothing bad happened, I think that the spark plug wasn't in all the way from the previous owner.
hardbound
Apr 22, 2012 09:22 PM
shwagy357
General Automotive Discussion
Feb 24, 2005 11:45 PM
sillyp
Modular V8 (4.6L, 5.4L)
Sep 28, 2004 06:43 PM
jldeeney
Modular V10 (6.8l)
Mar 22, 2004 11:16 AM
