Sponsored by: Real Truck
IAC Questions
Old Mar 17, 2015 | 02:43 PM
MacPhly's Avatar
MacPhly
IAC Questions
I just changed out my IAC. Truck is still idling too high. When I squeeze the host to the IAC it idles down. When I unplug the IAC the truck immediately dies.
Does the IAC talk to the the Throttle position sensor? Should this be my next part to change?
2002 F250 5.4L
Thanks
Old Mar 17, 2015 | 03:07 PM
Vwags's Avatar
Vwags
It used to be common on Fords that after a repair you had to disconnect the battery so the system can relearn with the new part otherwise there was a real possibility that you would have the same symptom. I don't know if that is still true for '02 but worth a try.
Old Mar 17, 2015 | 03:27 PM
MacPhly's Avatar
MacPhly
Interesting. Haven't heard of that before but worth a try.
Old Mar 18, 2015 | 07:32 AM
MacPhly's Avatar
MacPhly
Tried the brain reset but it didn't help.
I think the IAC I installed might be junk. Also picked up a new TPS but haven't installed yet.
Old Mar 18, 2015 | 08:03 AM
DavidB's Avatar
DavidB
bkbkbkbk
Sep 7, 2014 07:08 PM
quisp-n-quake
Sep 25, 2007 09:07 AM
live2hunt
1983 - 2012 Ranger & B-Series
Apr 1, 2007 06:46 PM
yardbird
Modular V8 (4.6L, 5.4L)
Mar 31, 2005 08:08 PM
PRSplaya
Jun 14, 2004 09:42 PM
