Sponsored by: Auxito
Gear Ratio?
Old Mar 17, 2015 | 08:58 AM
Rusty830's Avatar
Rusty830
Gear Ratio?
I got a 99 f150 5.4l 4x4 and the tires size 265-70-r17
Im changing out the end axle to disc brakes what gear ratio should i do and i know i need to change out the front axle too
Thinking about putting 33s or 35s tries on it
Old Mar 17, 2015 | 09:29 AM
F150Dad's Avatar
F150Dad
Hopefully the build sticker is still on the drivers side door jam. Find it, and report back on what the "code" is under AXLE......should be a letter and a number. Let us know what it is and folks will help you identify it.
Old Mar 17, 2015 | 09:40 AM
Rusty830's Avatar
Rusty830
B6 i think
3.73 gears
Asking to put different gear ratio like 4.10 gears
Old Mar 17, 2015 | 10:00 AM
F150Dad's Avatar
F150Dad
Mis-read your original post Rusty, my bad. I would go as deep (High Numerical) as I possibly could afford. Not sure if your carrier will support 4.10's and higher. You may have to switch carriers for the rear, and not sure on the front....it may be limited due to it's small size as to how deep of a ratio it could support. Good Luck!
Old Mar 17, 2015 | 10:13 AM
Rusty830's Avatar
Rusty830
Its cool!! Because i pick up a axle for a 02 f150 crew cab and that axle code is h9 for 3.55 gear ratio Is that better then 3.73 gears
Old Mar 17, 2015 | 10:50 AM
F150Dad's Avatar
F150Dad
For running bigger tires/wheels, ideally you want larger numerical final drive, like a 4.10 is better for being able to move a larger wheel with a stock engine than a 3.55. The problem you will most likely run into is with the carriers (what the ring gear bolts to) is that there are different carriers that support different ratios. As the numerical number goes up, the ring gear gets thinner because of more grooves. The lower numerical number, the fatter the ring gear is because of less grooves. The thickness of the ring gear dictates which carrier you will have to use. Each carrier will fit into the stock 9.75 inch rear end, but the different gear ratios need a specific carrier.
I hope I was able to half **** explain it .
Old Mar 17, 2015 | 11:16 AM
Rusty830's Avatar
Rusty830
Yeah both rear axle have 12 bolt cover 9.75
Old Mar 19, 2015 | 09:12 PM
steve(ill)'s Avatar
steve(ill)
The 265 tires on the truck now are 31.5 inch diameter. 33.0 would be 1.5 inch bigger or 5% ....... 35 inch would be 3.5 inch bigger or 12% bigger.
You have 3.73 gears now........ 4.11 is .40 bigger or 10%.
3.55 ratio is too small of gears for 33 or 35 tires.
Old Mar 19, 2015 | 09:36 PM
Rusty830's Avatar
Rusty830
kool that's what I what to know! so if I put 4.10 or 4.11 on my truck now with the 265 tires now will it hurt it any? intill I buy bigger tires for it
Old Mar 20, 2015 | 07:10 AM
steve(ill)'s Avatar
steve(ill)
No hurt. The motor will speed up about 10%... Lets say at 60 MPH your motor is turning 1800 RPM.. After installing the 4.10 gears it will run 180 RPM faster or 1980 rpm at 60 MPH
Joe Meg
6.7L Power Stroke Diesel
Jan 18, 2010 05:35 PM
Bino2
25
Apr 5, 2008 10:45 AM
funkie49
Apr 22, 2007 09:41 PM
RushN350
Dec 22, 2005 05:16 PM
liljase
Feb 28, 2004 12:41 AM
