leaking diesel .
Old Mar 16, 2015 | 09:21 AM
InductedCobra's Avatar
InductedCobra
leaking diesel .
Hey there I have a 2000 ford e450 and it's leaking diesel out of an overflow pipe underneath the alternator. What is causing this any ideas?
Old Mar 16, 2015 | 09:47 AM
AllaboutMPG's Avatar
AllaboutMPG
Under the alternator on the driver side? Does the e450 have a dual alternator set up with one on the right lower? The fuel bowl has a drain valve on the back and it is connected to an open ended drain tube that usually drains out passenger side above the axle. It's known to leak. Rebuild kit if is leaking
http://www.riffraffdiesel.com/fluoro...ve-orings-set/
Old Mar 16, 2015 | 09:54 AM
InductedCobra
passenger side.
It's on the passenger side under the alternator over the axel. It's a small tube and it drips diesel
Old Mar 16, 2015 | 09:55 AM
InductedCobra
I don't see a second alternator
Old Mar 16, 2015 | 09:59 AM
AllaboutMPG
e450 must be set up different. That is the drain tube from the back of the fuel bowl. Yellow handle can be turned 90 degrees to drain the bowl. Try opening and closing one time to see if it shuts off. Be warned it will dump a cup or so. Don't do it in the garage.
Old Mar 16, 2015 | 10:03 AM
AllaboutMPG
Picture of the back of the bowl
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Yeah, my guess is the fuel drain too.
Old Mar 16, 2015 | 10:16 AM
InductedCobra
Ok I will give that a try
Old Mar 16, 2015 | 11:13 AM
SaintITC's Avatar
SaintITC
I have a length of 3/8 fuel line that slips easily over that drain line by the block and into an empty 1 quart oil bottle. The entire contents of the fuel filter is just a little over half a quart. I run it through the little loop in the suspension by the tire so it doesn't fall over.
Name:  Fuel drain line.jpg
If you leave it there, it just kinda flips up by the lower ball joint and will stay there until the guy at the inspection station asks you why it's there.
69issofine
Electrical Systems/Wiring
Dec 10, 2014 02:53 PM
Ed M.
Aug 2, 2013 08:36 AM
DeathSpiral
May 6, 2010 11:13 AM
bigmacmonday
Feb 10, 2010 12:54 PM
jefff
Dec 1, 2007 07:36 PM
