Sponsored by: Real Truck
Ok, an easy one
Old Mar 15, 2015 | 08:56 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Ok, an easy one
Where are the diff fluid insersition points front and rear on the 4X4?
Thanks
Old Mar 15, 2015 | 09:05 PM
CampSpringsJohn's Avatar
CampSpringsJohn
There should be a plug on the pan on the back of the rear differential, and the pan is mounted on the front of the front axle. Fluid should be up to the threads.
Old Mar 15, 2015 | 09:06 PM
AAubinoe's Avatar
AAubinoe
the front dana is right on the cover I believe.
The rear is a bit different
Welcome to guzzle's Rear Differential Maintenance Web Page
Only thing I would add to that is its good practice remove a fill plug before ever removing a drain plug/diff cover.
Old Mar 15, 2015 | 09:11 PM
CampSpringsJohn
True. But I never found a drain plug on the F250's or F350's I've owned. Always had to remove the rear pan/cover to drain them. Do they have drain plugs on the newer trucks? My 08 has a bolt that you remove to drain the rear differential, but it's also an F450 with a much bigger differential.
Old Mar 15, 2015 | 09:48 PM
02GrayPowerStroke
Thanks guys!
Old Mar 17, 2015 | 10:52 PM
AAubinoe's Avatar
AAubinoe
oh yeah, i have personally never seen a drain plug on a diff with a removable cover. Some aftermarket diff covers do, like ARB.
Three30Eighr
May 16, 2019 09:30 PM
Notamechanic253
Jun 14, 2018 01:16 PM
jdq
1997 - 2003 F150
Feb 15, 2013 09:20 PM
l. norwein
Aug 6, 2007 02:18 PM
f_pumillo
Mar 28, 2004 07:47 AM
