Rear Differential
Old Mar 27, 2004 | 03:53 PM
f_pumillo's Avatar
f_pumillo
Rear Differential
Need some help. I finished changing the front diff, not too big a problem other than no room to use the gear oil bottles. Went to change rear, but not sure where the plug is to drain/refill oil. Only plug I see is about 1/4 the way up the pan on the driver's side. Uses what looks like 3/8 inch socket drive?
Is this right, doesn't look like I'll be able to refill the 3.3L it specs for??
Help
Old Mar 27, 2004 | 03:58 PM
johnsdiesel's Avatar
johnsdiesel
That's how it is on mine (Sterling 10.25") and should be the same on yours (Sterling 10.5"). In order to completely drain the differential you need to remove the cover. The drain/fill hole combination thing is just a bad idea. Buy some gasket maker and take the cover off. Not a tough job and you'll get all the old fluid out.
Old Mar 27, 2004 | 04:16 PM
f_pumillo's Avatar
f_pumillo
I have a vacuum pump I used for the front diff. Wasn't bad, just took forever to drain. Thanks for the quick response...
But the plug on the driver's side is the only plug?
Was also suprise, the manual says 1.8L of fluid for front, but I must have drained closer to 2 liters.
Old Mar 27, 2004 | 07:48 PM
johnsdiesel
Yep, that's the only plug. It's a poor design. I would recommend removing the cover rather than using the pump. It's really not that much of a pain and you can really let it drain and inspect everything. A fresh seal doesn't hurt either.
Old Mar 27, 2004 | 07:59 PM
f_pumillo's Avatar
f_pumillo
I'm take you up on going the pull the pan and put a fresh gaslket route.
Old Mar 27, 2004 | 09:11 PM
johnsdiesel
By the way, yes, it uses a 3/8" socket wrench.
Old Mar 28, 2004 | 07:47 AM
f_pumillo's Avatar
f_pumillo
Thanks again
