Sponsored by: Real Truck
Transmission Adaptive Learning
Old Mar 16, 2015 | 04:53 PM
seville009's Avatar
seville009
Originally Posted by droldsmorland
Off subject a little as were discussing the 5R110W trans. 6.2 uses the 6R140. How many miles on the fluid and filter and the transmission?
Transmission mileage is about 69,000. I think the fluid was changed around 45,000, but I don't think the filter was changed (not sure off hand; dealer did the work).
Old Mar 18, 2015 | 09:27 AM
tobyw's Avatar
tobyw
Originally Posted by tobyw
Subscribed... I've noticed a few times lately that mine gives a harsh 2-3 shift. Not always, but sometimes...
Originally Posted by Mark Kovalsky
Due to the nature of how the 2-3 shift is performed, once in a while you will get a harsh shift. It's releasing a clutch and applying another clutch to make that shift. If one finishes what it's doing more than 0.030 seconds faster than the other one it is going to be a bad shift. It proved to be impossible to make that shift perfect 100% of the time.
Wow, thanks for the info!!
Old Mar 19, 2015 | 10:42 AM
droldsmorland's Avatar
droldsmorland
I change the fluid and filter in an Automatic before or at the recommended intervals. Thats generally around 25K. You need to do it much sooner if you do any repeated heavy towing like 15K IMO...Mine will do a hard 2-3 upshift every so often. I think its the nature of the beast as to how 2-3 upshift is accomplished with this 6R140 trans. Not sure exactly how it does this shift as our resident Engineer (Mark) retired before it came out??? Mark?
I come from the high perf and muscle car world. IMO Id rather have a firm positive shift vs a smooth cushy one. The latter causes frictional heat and will deteriorate the frictions/steels and fluid faster over a firm positive shift.
IMO the 6R140 is superior to the 5R110W. I have not had either one apart yet to comment on how beefy they are internally.
Old Mar 19, 2015 | 10:58 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first 6R140 prototype was built on my last day at Ford Motor Company. I didn't go look at it, I had other things to do that day. I don't know much at all about that transmission.
Old Apr 27, 2015 | 01:54 PM
WK57ABF's Avatar
WK57ABF
Update to my original post concerning transmission hard shifting/shuddering/slipping.
While waiting for my transmission issues to heal, I decided to lube the rear drive shaft slip joint. Hells flames what a difference. Early days but after three or four shopping trips and one 20 mile 8000 lbs tow, this is a changed truck. No hard/missed shifts or judders or clunking - it's a miracle. It's so smooth.
Sorry for misleading you guys with a transmission problem when it looks as though it was just the drive shaft.
Thanks, John in the UK
Old Apr 28, 2015 | 10:05 AM
tobyw's Avatar
tobyw
Would you mind elaborating on how you lubed the slip joint? I have looked under my truck several times, and I don't have a grease fitting anywhere south of the ball joints...
Old Apr 28, 2015 | 10:38 AM
WK57ABF's Avatar
WK57ABF
Hi tobyw,
I dropped the rear drive shaft by removing 4 x 8mm bolts (08 SCLB 6.4). Pulled the yoke off the splines and greased with Motorcraft XG-8.
If you Google or search this forum (Super Duty Yoke Slip Joint) there are dozens of threads on the procedure.
Surprisingly there are no grease fittings as there were on the older trucks.
John in the UK
Old Apr 28, 2015 | 11:14 AM
droldsmorland
I put a link on the 1st page of this thread on slip spline re-grease^^^
spud57
Aug 29, 2017 06:24 AM
popeyenelson
Jan 13, 2010 02:09 PM
almo192000
1997 - 2003 F150
Jan 22, 2008 06:48 PM
reel_scream
Oct 18, 2004 08:58 PM
