Sponsored by: Real Truck
Catastrophic 2-3 shift
Old Aug 28, 2017 | 04:56 PM
spud57's Avatar
spud57
I experienced a 2-3 shift today that felt like my 5th wheel unhitched and landed on the truck.
The sensation and sound was sickening.
I just pulled out on the highway, 9500 lb 5th wheel in tow, tow haul on, moderate acceleration, when the 2-3 shift sounded and felt like a bomb went off. 2011 with 50k miles. Rather bizarre if you ask me.
I know the 2-3 shift is rather unique. Combines an upshift and down shift at the same time. I think at the moment it was shifting, I may have put my foot into it a bit more. Maybe the tranny got a little confused?
Not sure if I should head off to the dealer and have them check it out. Has been okay since.
It was quite frightening. Wife thought the trailer fell off.
Any thoughts, comments, experiences?
S
Old Aug 28, 2017 | 06:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That was true for the 2003-2010 5R110W five speed TorqShift. It is not true for the 2011 and newer six speed TorqShift.
That could be what happened.
If it isn't doing it again I doubt the dealer is going to find anything.
Old Aug 28, 2017 | 07:23 PM
seville009's Avatar
seville009
I've had it happen 3 or 4 times in my 2011, each time when doing normal acceleration from a parking lot onto a road (not towing). Hangs in 1 and then revs and slams into 2. Last time it did it was maybe a year ago. Have about 94,000 miles on it. Doesn't seem to have any lasting effects. Researched it awhile back and evidently it's not out if the ordinary.
Old Aug 29, 2017 | 05:26 AM
spud57's Avatar
spud57
Thanks guys for the quick response. I'll wait and see if it happens again.
S
Old Aug 29, 2017 | 05:41 AM
Brettb1's Avatar
Brettb1
Have them scan for a wheel speed sensor code. My 2011 has done it twice. It hangs the RPM up high and then slams the next gear hard. I think the traction control may have sensed a wheel slip causing the traction control to activate and then releases and slams a gear. Now with that being said I know I didn't spin a tire so that's where the wheel speed sensor comes in, It may be dirty or just not functioning properly and I think can cause this proplem.
Old Aug 29, 2017 | 06:22 AM
russ68's Avatar
russ68
8th Gear
My 2014 has a hard 2 - 3 shift on occasion. Only ever noticed it when not towing. I've got 110k on the truck.
Old Aug 29, 2017 | 06:24 AM
rdlouks's Avatar
rdlouks
Perhaps this may help you. https://www.ford-trucks.com/how-tos/...oo-hard-361579
My Brother has a 2011 F-350 with the 6.7 Powerstroke and he had the same issue. Dealer replaced the pressure control solenoid and it took care of the problem.
redman84
Jan 21, 2011 12:42 PM
DUKFVR
Modular V10 (6.8l)
Aug 18, 2005 07:34 AM
