Transmission Build
Old Mar 13, 2015 | 06:19 AM
bass-n-fire's Avatar
bass-n-fire
Transmission Build
Ok, with everything I've been doing to my truck lately, I'm looking into building a transmission. I'm looking at building it myself. It's not something that I need right now, but would like to do. I would be taking my time building it and not rushing it. I'm pretty handy with the tools, and what I don't have, I have access to. I'm not afraid to tear into something. I guess you never know what you can do until you try, right?
A couple of questions to start. I just saw an E4OD on Craigslist. It's out of a 1990 F250. It's not a 4x4. Will this be a good candidate to start with? Or do I need to start with one out of a 4x4?
And it is from a 7.3 IDI.
Old Mar 13, 2015 | 06:40 AM
DIYMechanic's Avatar
DIYMechanic
The bolt pattern of the main housing would fit your PSD, but you need a 4x4 trans so you have the correct tail housing.
This is something that I have always wanted to do. I hate that I'm intimidated by the innards of an automatic transmission, but I have never had the opportunity to do a rebuild myself. I'm always under the gun to get it done and can't afford to have it fail on me (that's partly why I have a ZF5 now). I wish you luck on the project. I'll be watching, though I doubt I'll have much to add.
Old Mar 13, 2015 | 06:48 AM
bass-n-fire
Thanks for the quick answer. I was thinking the tail housing would be an issue. Like I said, there's nothing wrong with my current transmission, other than being stock. So, as of right now, I have time to research, gather parts, and research more. I will get the parts needed a little at a time. It's just one of those things that I want to try. My truck has been down long enough as it is, and don't have the funds for a rebuild after what I've spent so far. If I follow through with this, I will keep updating.
Old Mar 13, 2015 | 06:50 AM
fordman67's Avatar
fordman67
No,you need a PSD sourced trans. The previous idi trans has less of the improvements that you do need.
Old Mar 13, 2015 | 07:08 AM
DIYMechanic
Racer X is a good source for the parts as well. They make some good stuff and they'll sell you whatever you need piece meal, or you can buy a whole kit. If you just want the valve body and a converter, they'll sell you just that.
Old Mar 13, 2015 | 09:19 AM
bass-n-fire
Good deal. Just beginning the thought process, so any advice or direction is welcomed.
Old Mar 13, 2015 | 10:51 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The earlier ones (pre-95) are weaker and will need a lot of hard parts to be replaced.
The 4x4 or not isn't too big of an issue. You have to swap the output shaft and the tailhousing. Output shafts can be expensive. You could swap the tailhousing off your current trans when you install the trans. You can't swap the output shaft at that time because the trans has to be totally disassembled to swap the shaft.
You'll need a good manual. There are good ones at Automatic Transmission Service Group.
Old Mar 13, 2015 | 06:49 PM
quesey's Avatar
quesey
sent you a PM just give me a shout if I can help you
I can give you some pointers on a few things. but like they said start with a newer style e4od 96 or 97. an you can get the output shafts on zbay and just swap your housing.
They aren't that bad once you do 1
some of the right tools help a lot
I can send pics of the ones I made
good luck John
Old Mar 14, 2015 | 10:05 PM
bass-n-fire
Thanks John. I will definitely hit you up when the time comes.
Old Mar 14, 2015 | 10:16 PM
fordpride's Avatar
fordpride
E4OD rebuild
joegeds
Mar 21, 2015 03:29 PM
JonathanN
18
May 10, 2012 09:06 AM
73strokin
Feb 17, 2009 09:14 AM
sckootter578
Pennsylvania Chapter
Oct 13, 2007 06:11 PM
Ranch57
May 3, 2006 09:55 AM
