oil filter location problems
Old Mar 9, 2015 | 12:13 AM
loveless41908's Avatar
loveless41908
Im currently installing a freshly built 460 back in my 86 f250, its the original engine just the block is different. By different i mean its actually a 1971 429 block n i took all the parts from the original engine n built it into a 460. The oil filter adaptor in the block doesnt appear to be removable, anyone know how to get that out of the block so i can possibly use the original filter adaptor that bolted to the 86 block?
Old Mar 9, 2015 | 06:41 PM
davistr's Avatar
davistr
When i put my 79 460 in my 84 F350 I had to cut the frame out to fit a remote oil filter system on it. Then mounted the filters to the core support!
Old Mar 12, 2015 | 05:08 PM
mark a.'s Avatar
mark a.
Internal pipe wrench and some heat.
Old Mar 13, 2015 | 09:31 PM
loveless41908
Interesting...any particular one work better than the other?
Old Mar 15, 2015 | 02:16 PM
cbakker's Avatar
cbakker
referring to wrench and heat? You will need both. It shouldn't take much heat and you don't want to get the block red hot in any one spot.
Old Jun 1, 2015 | 10:49 PM
loveless41908
Better late than never.....
I ended up using a big ol monkey wrench to remove the original filter mount stud, destroyed it but at least it gave me a better idea n a visual on what i needed. Lucked out n found a local guy that had the part i needed, guess it was common on ford E vans
AAPatten
Oct 5, 2011 11:04 AM
djmac
Jun 14, 2007 01:46 AM
justshootme84
Nov 18, 2006 05:54 AM
Brian460
Jul 22, 2002 02:24 AM
