Boost Gauge
Old Mar 10, 2015 | 02:53 PM
smithm31's Avatar
smithm31
Thanks Nate. I see what the map line is now and I think I will Tee into it first and see if it will be satisfactory before I start drilling and tapping. I did order a DP Tuner chip about two years ago and installed it per their instructions. Can't believe the difference it made in the truck. Thanks, Mike
Old Mar 12, 2015 | 01:15 PM
Airstreamer67's Avatar
Airstreamer67
I installed a T fitting into the MAP line because it was so simple to do without needing to drill and tap. My boost gauge's needle does vibrate a little under heavy acceleration, but it settles down and is easy to read and has created no problems over the years.
I believe it is common for stock engines to see 17 or 18 psi under full effort, approaching 20.
VinylSock
18
Dec 15, 2011 12:24 PM
6.9idiatsturbo
Jun 22, 2011 10:54 PM
ttttmaxx
Jan 14, 2008 02:50 PM
zstyle01
15
Apr 7, 2007 10:32 PM
goalie
Jul 5, 2002 06:01 PM
