I'm thinking that my oil pump is leaking. I bought this 64 Styleside LB with a 292 2bb and 4 speed. The PO said that it ran strong but might need to be overhauled as it used copious amounts of oil. He is right!
I'm thinking that the oil pump is leaking. I've been able to tighten enough stuff and insert bolts into the heads at the back...thanks to the info available here to get the engine to idle well for an hour at a time without leaking. Yahoo!
Then I get in her and go ten miles, well now I'm down a quart and what a mess! There is no way that the rear main could throw that much in that length of time.
So I know that I have a gear style pump and I can't see it leak at idle. Anybody got any thoughts?
Well when I open the hood everything from the back lower part of the engine is wet with oil. The most is concentrated around the driver side. I have a road draft tube that was leaking when I got it. I've replaced it with one that is round and serviceable. The original was not round and PO had used epoxy at the bottom of the can. So the replacement helped.
Next I read a post where someone was thinking about replacing his rear main seal, but he thought he should check his oil pan bolts. Sure enough they were loose and he tightened them to 15 ft pounds.
So I checked mine and sure enough mine were loose also. So now I've got them torqued as well.
I checked the pipe from the pan to the oil pump and it was tight. Then I checked the pipe at the pump....it was loose. So I tightened it. Well I thought that must be my problem! Maybe not.
That's when I did the idle test. No new leaks.
When I drive its another oil bath. The oil is everywhere under the pan but mostly on the steering box. It's so much that when I get back home oil drips off the rear axle. Just too much to be all rear main. IMO
Huh. Well the key is cleaning everything up really well, to find the actual source because oil will travel far and confuse the issue. Guess you know that already.
Before you take things off, why not do a little cleaning, then set the idle screw up so the engine runs around 2 grand. And with the truck blocked from moving, roll part way under it, and watch where the oil drips from. If it drips from the weep hole in the clutch cover, its probably the main seal. The oil sending unit is also in that area, watch it too, and the valve covers are known to leak too.
That's a good suggestion. I wondered how to get it running fast enough to actually be able to observe what was happening. I don't think I have a clutch cover....My flywheel and pressure plate are exposed. Isn't that what the cover would hide?
So I ran the engine at about 2000 rpm while observing what leaked. The oil pump, sending unit, oil filter,valve covers, & road draft unit didn't leak. The oil kept leaking from the cross member under the 4 speed transmission. I can't see a leak so I'm assuming the rear main is leaking and it is flying off the flywheel onto the inside of the bell housing and gravity is allowing it to drip down to the bottom where it gets collected onto the cross member until it drips.
At least you isolated the problem. You (or somebody) have to replace the rear main seal. There's some tricks to it - and some recommend using a neoprene type, others say use only the rope OEM type.
I pulled the motor to do mine, but it can be done in the truck if necessary. For me, it was a good time to clean stuff up, change motor mounts, etc. The pump and pan will have to come off, but the timing cover can remain in place.
There's a sub-forum dedicated to the Y-Block on FTE--try this thread on the rear main (there are others to read, however!):
I love the Y-Block, but the rear main appears designed to leak. The seal is a three-piece unit. The cap used to hold it on is aluminum; it has two holes for oil pan bolts that tend to strip. You may want to put studs there, if possible, to prevent additional leaks.
