repeated alternator failure
Old Mar 6, 2015 | 06:29 PM
diesel_dan's Avatar
diesel_dan
Originally Posted by MC5C
my understanding is that the PCM selects and controls which alternator is on during the glow plug on phase of engine start up, then controls which alternators are on - one or both - in response to load. I can see a scenario where only one alternator is being switched on at a 90 amp load, and that is pretty high for just one alternator continuously.
Brian
First off: Sorry Brett -- I must've speed read right past your post as you were on this 1st.
Interestingly a friend's dual set up didn't tell him when one Alt went out, it was only when the second one started to go. So seems plausible that it is keeping one fully loaded and then switching when it dies to the other one...
Old Mar 7, 2015 | 03:30 AM
Yahiko's Avatar
Yahiko
Do a voltage drop test on all cables and grounds.
You could have a bad cable that you can't see and
the only way to find it is a voltage drop test.
Sean
51ratrodspud
Jun 30, 2019 09:43 AM
mxer0022
May 31, 2013 09:03 AM
frenchy107
Mar 15, 2011 02:07 PM
cemiii
Jan 2, 2010 06:43 PM
docholiday72tx
Electrical Systems/Wiring
Jun 22, 2005 07:39 PM
