stock alternator
Old Aug 14, 2012 | 02:05 AM
mxer0022's Avatar
mxer0022
stock alternator
ok here is a dumb questions but i am pretty sure my alternator is getting ready to take a dump on me cause the battery light keeps coming on while i idle so i was pricing out alternators in preparation but am finding 110 amp and 140 alternators. i am not sure which one the dual setup takes and which one the single setup takes. mine is the single.
also if mine is only a 110 amp would it hurt if i put a 140 on it?
thanks for the help guys
Old Aug 14, 2012 | 02:55 AM
bismic's Avatar
bismic
You can install the 140A w/ no problem. In fact that is a better choice than the 110A model.
Alternator - 140A (F series) 6C3Z-10346-BARM
Old Aug 14, 2012 | 08:22 AM
DSMMH's Avatar
DSMMH
I put a 160 amp aftermarket alternator on mine. It bolted right in to place and has worked fine for 5 years.
You might want to add a second wire from the alternator output to the passenger side battery. I added a piece of 2/0 gauge wire on mone. The OEM wire is sized for the 110 amp alternator so if you exceed the 110 amp for a sustained period of time you may cause the wire coating to melt and a possible fire. Not likely, but possible.
DSMMH
Old Aug 14, 2012 | 06:37 PM
mxer0022's Avatar
mxer0022
Awesome! Thanks for your help guys and thanks for that p/n mark!
Old May 31, 2013 | 12:09 AM
mxer0022's Avatar
mxer0022
Quick question again mark and dsmmh. I just had to pull the trigger on an alternator today and I bought the 140. I also had to replace my cracked degas bottle. While I was waiting for the thermostat to open to see how much more coolant I might have needed to add I felt the charge wire at the alternator and it was pretty hot! Hot enough to soften then insulation. Is this normal? How much heat can this wire take? Does the wire get that hot withthe 110 amp alternator?
Old May 31, 2013 | 04:40 AM
bismic's Avatar
bismic
That wire gets plenty hot. It has been so long since I ran the 110A OEM unit, I can't recall exactly how hot though. MY DCPower alternator gets my 2/0 wire quite hot.
Can you shoot the wire with an infrared heat gun to get an actual temperature value?
Old May 31, 2013 | 08:05 AM
mxer0022's Avatar
mxer0022
I might be able to get a temp! I'll try and post later today and let you know!
Old May 31, 2013 | 09:03 AM
Misky6.0's Avatar
Misky6.0
You can do like DSMMH suggested and ADD another large wire between the alternator and PASS side battery to handle the added power.
gwalker12
May 26, 2018 01:11 AM
jamie7375
Mar 16, 2009 05:55 PM
Trickedout420
Jan 28, 2007 09:37 PM
bigin302
Aug 4, 2002 04:13 PM
