Remote and key compatability?
Old Mar 3, 2015 | 09:35 PM
Pele's Avatar
Pele
I just hopped into some of the newer 2014 and 2015 Explorers and F150s at work. I noticed they're still using the same key blank, as my Excursion and Crown Vic keys fit in the slot.
I like the remote fob built into the key head.
Are the newer remotes and PATS keys compatible with the Excursion's Keyless system and PATS module?
Old Mar 4, 2015 | 05:43 PM
JuanHuevos's Avatar
JuanHuevos
I can't say for sure about the Ex. But I can tell you that on my 2005 F-150 there was a key and separate remote. I bought a key for a Fusion, it had the same blade length as the F-150 key and it had the fob built in. It worked just fine once cut and programmed. So I would imagine that will a little research, there is the possibility of a combined key/fob for the Ex.
Old Mar 4, 2015 | 05:54 PM
05MilMachine's Avatar
05MilMachine
They sell VW style flip keys for my focus that work. Hopefully someone knows about the Ex as i really want to consolidate my keychain.
Old Aug 24, 2015 | 03:45 PM
psycoreefer's Avatar
psycoreefer
anyone make any progress on figuring this out, I'd love to have the combined fob/key as well.
Old Aug 25, 2015 | 10:48 AM
Pele's Avatar
Pele
I did verify that the REMOTE from a 2015 Explorer, 2010 Expedition, and 2013 Transit Connect will operate the Excursion locks and vice versa.
It seems all Ford REMOTES are compatible.
To get the key head with the built-in remote into the Excursion ignition will take a bit of filing of the shroud around the key hole.
I don't know how to program the PATS without going to the dealership. Couldn't verify if the newer PATS chip is compatible with the Excursion PATS module. I wish I could rip it out. I don't want to pay a hundred bucks to program a key at the dealership.
Old Aug 25, 2015 | 11:34 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Do you already have two keys?
https://www.ford-trucks.com/forums/5...-pats-key.html
Old Aug 25, 2015 | 01:44 PM
Pele's Avatar
Pele
Originally Posted by Archion
Nope. One key.
Just gonna copy it to a regular key and zip tie the head inside the steering column.
Old Aug 25, 2015 | 02:12 PM
Archion's Avatar
Archion
I'd have to look at the later key on my wife's escape, but I know the Excursion key you can pop the RFID pill out of it, same as my Mustang. There is a door in the top of the key that you can remove.
Old Aug 25, 2015 | 02:34 PM
Pele's Avatar
Pele
This is some generic Locksmith key. I can clearly see the RFID pill because the head is clear. It's embedded in the plastic.
Old Aug 25, 2015 | 02:55 PM
Archion's Avatar
Archion
Yeah, but I was thinking about when you mod the trim ring to accept the later key.
khadma
2015 - 2020 F150
Dec 24, 2015 05:02 PM
Calixto
1997 - 2003 F150
Nov 9, 2014 01:09 AM
cchsbuzz19
General Automotive Discussion
Oct 12, 2014 09:25 PM
NukeUFO
2004 - 2008 F150
Sep 3, 2014 04:23 AM
