Oil Testing
Old Mar 5, 2015 | 10:19 AM
F350-6's Avatar
F350-6
Unless you have a really big problem you're worried about or are wanting to compare new vs. used to see what shear is doing to the oil, then yes, it's a waste.
Old Mar 5, 2015 | 10:27 AM
queen of spades's Avatar
queen of spades
I would like to see what new looks like this one time. Then again at next oil change I can compare.
Old Mar 5, 2015 | 10:32 AM
white Buffalo's Avatar
white Buffalo
Then send in a virgin sample from the container or you might find the results at bobistheoilguy.com
Hey Chis - who ya callin funny accent! Fagetta bout it 😎
Old Mar 10, 2015 | 08:17 PM
jhl3's Avatar
jhl3
Originally Posted by white Buffalo
Plus there are some very nice synthetic full flow filters out there.
I am interested in learning about them. Would you share that information?
Old Mar 10, 2015 | 09:18 PM
white Buffalo
Sure will!
These are the filters I normally use in conjunction with the Oilguard Bypass filter on the F-250.
From Fleetfilter at $13 each
Wix 51734 & Napa 1734 Oil Filter: FleetFilter Secure Online Store - Wix, Fram, LuberFiner, Baldwin
On the Excursion after the engine rebuild I started using these. has a 10 micron rating compared to the 20 micron rating above, but at the same flow rate as the above full flow filter.
From Fleetfilter at $23 each
Wix 51734XE & Napa 1734XE Oil Filter: FleetFilter Secure Online Store - Wix, Fram, LuberFiner, Baldwin
Old Mar 11, 2015 | 07:07 PM
jhl3's Avatar
jhl3
Sure will!
Awesome! I will check those out. Thank you, sir!
Old Mar 11, 2015 | 07:34 PM
white Buffalo
They have some great prices on the 6637 air filters, oil filters, coolant filters.....etc.....
Old Mar 11, 2015 | 09:54 PM
bigb56's Avatar
bigb56
I've been using the Fleetguard LF 9207 bypass filter. Kinda pricey but what the heck, so is a new truck. I am just doing my first oil analysis at 160K, expecting it to come back good.
53FOPAR
23
Jun 11, 2022 11:21 PM
VoodooRacer
16
Apr 14, 2012 07:27 AM
usmc5953
May 27, 2008 11:00 PM
squaredancer
Apr 25, 2008 05:45 PM
V92c
Oil & Lubrication
Jul 11, 2003 09:39 AM
