Curt hitch - report from towing section
Old Feb 7, 2017 | 06:58 PM
Blue and White's Avatar
Blue and White
Not a Kurt... but similar I believe. I left the tank loose, installed the hitch then snugged everything up. Close but fits fine.
Old Feb 8, 2017 | 07:17 AM
bradphx's Avatar
bradphx
Originally Posted by HoustonDave
Judging by the hitch drawings they sent me that is correct.
Bolts pointed down.... d'oh!!! Yep, that'll work. Worst case I may need to loosen the tank to shift it enough to get the bolts in place and then tighten everything down, probably using a crowfoot on the bolt heads. That big tank is a pain in the butt in some respects... NO BODY makes a gas gauge sender for it, the closest one I think is a 33 gallon sender.
check these out.
Part one
https://youtu.be/FUNMcLN3xLc
Part two
https://youtu.be/k0_rN-9D9tY
Old Feb 9, 2017 | 10:39 AM
HoustonDave's Avatar
HoustonDave
and just to close out the thread.... never did get around to the hitch, decided that the tow capacity is just too low as is and it will wait until I do something silly like changing the gearing. Haven't towed anything heavier than a car on a front-end dolly since I bought it, so no pressure and other things (like house flooding) got in the way. (However, I did get the gas gauge issue addressed - tank reads over full for the first 9 gallons, takes another 10 to hit half full, still has about 9 gallons left when it shows empty - so its response is pretty linear and predictable. Good enough.)
emeraldcoupe
Jun 9, 2017 01:08 PM
HoustonDave
Mar 10, 2015 09:25 PM
Inline6xl
Jul 16, 2014 06:50 PM
RockWVU
All Things Towing
16
Oct 3, 2011 06:09 AM
TexasGuy001
Nov 25, 2006 08:27 AM
