Power Brakes
Old Sep 7, 2015 | 10:53 AM
  #31
ultraranger's Avatar
ultraranger
Originally Posted by kdaug5
Hey Ultraranger great info. I'm also changing my booster and I went with the Explorer master cylinder like you. What rod or rod length did you use for the Explorer master cylinder.
For me, with the F250 booster and master cylinder I had before, the rod was 5 1/2" long and with the remanufactured booster I got the rod is 4 1/2".
Should I use the longer rod like before with the Explorer master cylinder or the shorter rod?
It's a difference of 1" and from what I understand if the rod is to long it will keep the brakes applied and to short maybe the pedal will hit the floor?
Thanks
Kenny
The booster input and output rods are separate but are attached, internally, inside the booster. They shouldn't just slide out of the booster housing. The output rod, not the input rod, determines the engagement length to the MC. There should be .005"-.010" inches clearance between the tip of the output rod to the primary MC piston, with the brake pedal in the static position (brake pedal NOT being applied).
I don't know what booster you have or, if it has a threaded input rod eyelet that's adjustable in length (?).
This is a single diaphragm booster from a '68 F250 that I have. It has an adjustable input rod and of course an adjustable output rod to the MC. The adjustability in the booster input rod only sets the height of the foot pad on the brake pedal, in relative distance of the foot pad away from the floor. Shortening or lengthening of the booster input rod doesn't alter the pedal ratio. The only way to alter the pedal ratio is to increase the distance between the brake pedal pin and the brake pedal fulcrum pivot.
This is a '74 F350 dual diaphragm booster I have that's very similar the the '75 F350 dual diaphragm booster that's on my truck. --only difference is the added plate across the face where the MC bolts up and the extra plate that wraps around the back side of the booster housing.
The output rod to the MC is adjustable.
....the input rod is a fixed length (non-adjustable), just like on my '75 F350 booster.
I didn't change or alter the input rod on my '75 F350 booster. It just connected directly to the pin my my '69 F100's brake pedal.
This is the method I used to adjust the booster output rod depth to the '95 Explorer MC.
http://api.viglink.com/api/click?for...FMMBAK-1r1.pdf
DieselBeast01
24
Jan 26, 2021 03:41 PM
jtexfisher
Aug 1, 2016 06:51 PM
400inatruck
Sep 5, 2012 09:50 PM
Caleb H
16
Jan 8, 2009 01:58 PM
lt dan
Jul 3, 2001 08:01 AM
