new brake booster problem
Old Sep 2, 2012 | 07:54 PM
400inatruck's Avatar
400inatruck
I replaced my booster and master cylinder, first I need a rundown on how to bleed the brakes properly and second, my brake pedal is about an inch and a half from the floor, not much travel at all. does the booster arm on the back of the booster screw in as in to pull the pedal up?
Old Sep 2, 2012 | 08:40 PM
OldStyle's Avatar
OldStyle
Rusty Roller
First, Did you buy these as a "set" meaning did they come in the same box; bolted together?
If separate you need to check the adjustment length of the push rod. (booster to master)
Either way you will need to "bench" bled the master cyl by it's self preferably in a vice before installing onto or back onto the booster.
Then you can install it/them onto the truck and bled the system.
Old Sep 2, 2012 | 08:49 PM
400inatruck
yes, as a kit. how do I bench bleed it?
Old Sep 2, 2012 | 09:22 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Here is as good of an explanation as any....
Bench Bleeding - YouTube
Old Sep 5, 2012 | 09:50 PM
400inatruck
Fixed the problem with the brake pedal height and got the master cylinder on. Now I gotta bleed the system as whole.
AbandonedBronco
1978 - 1996 Big Bronco
41
Jun 14, 2022 08:40 AM
DieselBeast01
24
Jan 26, 2021 03:41 PM
Rusty_S
Oct 1, 2016 11:34 AM
hulaman
13
Jun 24, 2016 11:24 AM
goldigr
Nov 4, 2003 07:55 AM
