brake booster/hydro booster
Old Dec 21, 2009 | 04:57 PM
DieselBeast01's Avatar
DieselBeast01
Can anyone tell me anything about the hydro booster in the super duty trucks? Mine has gone out and it is costing me a fortune to get it fixed.
Old Dec 21, 2009 | 06:57 PM
big poppa's Avatar
big poppa
Here's a bump Clint, no idea on those boosters.
Old Dec 21, 2009 | 07:54 PM
riverrat41's Avatar
riverrat41
Clint...Tell us the symptoms if any.I would like to learn more about this.No brakes at all?
Old Dec 21, 2009 | 09:51 PM
DieselBeast01
yes no brakes at all. Mechanic said that it was either the hydro booster or master cylinder. There are no leaks in the break lines or or at the calipers. When you push down on the pedal it just goes to the floor. The reservoir is full and is not leaking nor is the master cylinder.
Old Dec 21, 2009 | 10:06 PM
mueckster's Avatar
mueckster
Sounds more like internal bypass of fluid in the brake master cylinder or air in the system. Hydroboost failure would cause a hard pedal.
Old Dec 21, 2009 | 10:29 PM
SpringerPop's Avatar
SpringerPop
Roland has it! Reps to him!
The hydroboost only puts the POWER in power brakes.
Even without the hydraulic pressure from the "power steering" pump, you WILL have brakes. Just not POWER brakes.
The same is true with your power steering if you lose the hydraulic system. You'll still have steering, just not power steering.
If you have NO brakes, i.e. pedal to the floor, it's not the hydroboost, it's the master cylinder.
Pop.
Old Dec 22, 2009 | 07:14 AM
riverrat41's Avatar
riverrat41
This is the reason I was asking for more info.I was also thinking he had a master cylinder problem and the H.boost was fine.Reps to both
Old Dec 22, 2009 | 07:16 AM
riverrat41's Avatar
riverrat41
Sorry Roland,rep bandit got me on yours
Old Dec 23, 2009 | 04:10 PM
DieselBeast01
Hate to break the news to you guys, but u were wrong. It was the hydrobooster. I got the truck back today, and the breaks are like brand new. It will stop on a dime.
Old Dec 23, 2009 | 07:25 PM
SpringerPop
I fail to see how that could happen, but you never know....
This sparks a bunch of research for me, because now I have to know why the pedal went to the floor as a result of a bad hydroboost unit, given the fail-safe design.
Would you be willing to ask your mechanic the exact nature of the failure?
Pop
Old Dec 23, 2009 | 08:12 PM
banjopicker66's Avatar
banjopicker66
I agree. I also would like to know more. The hydroboost system hasn't changed much in decades. A problem causing a brake pedal to feel like stepping on a plum isn't a symptom of which I am aware.
(with apologies to C.W.McCall!)
Old Dec 24, 2009 | 11:18 AM
DieselBeast01
Yes I will ask him today. I have a family dinner to go to later and he will be there cause he is my uncle. Ill ask and see what he says.
Old Dec 24, 2009 | 12:32 PM
lhud's Avatar
lhud
I'm in agreement with you guys - it should have been the hydrobooster.
I had a GMC with a hard brake pedal and I replaced the vacuum booster and all was fine.
There is something else going on there or maybe there is some sort of bypass that is acting up.
Interesting.
Old Dec 24, 2009 | 02:47 PM
SpringerPop
But he didn't have a hard brake pedal. His went all the way to the floor, instead. That's a sign of a failed master cylinder.
That's why we're having such a hard time figuring out what might have gone wrong with the hydroboost unit that would cause the same symptom.
Pop
Old Dec 24, 2009 | 02:49 PM
mueckster's Avatar
mueckster
Suscribing....I want to hear this.
