Sponsored by: Real Truck
Ignition Key for 2014 F350
Old Mar 2, 2015 | 03:08 PM
3Nails's Avatar
3Nails
I would like to have a blank ignition key to store inside of my truck to use in case of lost key / emergencies. I went to WalMart to get one made and the guy said that I had to have one made at the dealer because of the encoded information. Didn't make sense to me, but what do I know? I thought the encoding was in the faub and had nothing to do with the key itself. I do not have memory seat adjustment or anything. There is nothing on the key itself. I have the XLT package. Any ideas? Thanks.....
Old Mar 2, 2015 | 03:20 PM
Just Strokin's Avatar
Just Strokin
You need a key an 80 bit chip in it. You can buy the keys on eBay and then take some place to have it cut. The your current keys will have and any keys you buy will need have SA stamped on it.
You will need 2 previously programmed keys to program the new key(s). You user manual tells you about it. I have a programmed key I keep in my truck for the same reason you mentioned. It is nice to walk out and times and not have to take your keys with you.
here is a listing for 2 keys that I have purchased before.
Pair New Lincoln Mercury Ford Transponder Chip Ignition Keys w 80 Bit Chip | eBay
The actual encoding is in the PCM/ECU.
Old Mar 2, 2015 | 04:14 PM
3Nails's Avatar
3Nails
Got it!!!! Just ordered two blanks for $12.95. Appreciate the really quick reply. Thanks a lot, Larry.
BigNiner19
2004 - 2008 F150
13
Apr 5, 2011 07:45 PM
jcaspersnow
1997 - 2003 F150
Mar 13, 2011 08:26 AM
tapout
1997 - 2003 F150
Sep 14, 2006 06:49 AM
Hello
Apr 28, 2005 12:55 AM
rayban33
1997 - 2003 F150
Jan 22, 2004 12:45 PM
