Aerostar Ford Aerostar
door ajar light concern
Old Feb 28, 2015 | 09:11 PM
Brian Skinner's Avatar
Brian Skinner
Hows it going. I had a concern especially when cold outside. Ocassionally the door ajar light illuminates when going over bumps or turning, more like flashes and the module/ relay buzzes. No chime goes off so i dont think the drivers door is the culprit. I do know that going on the interstate it sounds like a wind tunnel and even with the slider closed i can see the outside at the top closest to the rear side window(non sliding window behind sliding door). Please help me its been irritating and we want to fix it right not hack meaning not just unpluging things just to squeak by
Old Feb 28, 2015 | 09:29 PM
93nighthawk's Avatar
93nighthawk
From your description, Odds are it is your sliding door causing this issue. Over time the roller wears down and affects the alignment so the contacts are not contacting fully. Also the contacts corrode and wear down over time. Check the ones on the door side and the b-pillar.
There is a write up on how to replace the bottom roller with a bearing that will solve the issue of alignment.
Old Feb 28, 2015 | 09:32 PM
Tedster9's Avatar
Tedster9
Don't know what kind of switch is used here, though generally they get crudded up. (If it's not the sliders or misalignment) I'd try some electrical contact cleaner or WD-40.
cabldawg
May 31, 2022 05:08 PM
big blue
Feb 28, 2019 05:55 PM
dartman48
Jun 12, 2008 05:33 PM
TitleSeventeen
Aerostar
Mar 8, 2006 06:59 PM
Ultramagdan
1997 - 2003 F150
Dec 4, 2002 04:06 PM
