My Door is Ajar?
Old Jun 10, 2008 | 12:01 PM
dartman48's Avatar
dartman48
My Door is Ajar?
You all know, that if your door is not closed fully, you'll get the light on the instrument panel, and the dome light will stay on.
Well, I'm getting that all the time now. The dome light goes off after about 15 seconds of driving, but the dash light stays on. I've re-closed all doors, but no change.
My question is: what triggers the "door ajar" signal? Used to be, there was a contact switch on the pillar that the door compressed. I don't see that anywhere. What's the trigger?
Old Jun 10, 2008 | 12:03 PM
Joe's Creations's Avatar
Joe's Creations
try this link
RV.Net Open Roads Forum: Door Ajar Light stays on after doors are closed
Old Jun 10, 2008 | 12:05 PM
Joe's Creations
The door switch is part of the door latch assembly. A spray of WD-40 will help it if it is sticking, but you should also check the door adjustment. If the back of the door does not sit flush with the pillars and sits further out, then the door needs to be adjusted in.
You can adjust it by loosening the screws for the striker plate just enough to move with the tap of a hammer. Tap it in a small amount at a time until the door sits flush with the pillar. You can scratch a mark around the striker plate as a reference to how much to move and in case you make a mistake you can return it to where it was.
Locking tab.
Door ajar switch.
Additional Information provided courtesy of ALLDATA
Old Jun 10, 2008 | 12:10 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Spray the crap out of the latch with WD-40 or your brand. Work the door a few times while spraying. Should fix the problem, did mine and lots of other peoples.
Old Jun 10, 2008 | 02:09 PM
dartman48's Avatar
dartman48
Thanks guys. As always, the responses are quick and helpful. I didn't think to look at the latch assembly.
Old Jun 12, 2008 | 05:00 PM
dartman48's Avatar
dartman48
All fixed. The advise given on this forum is some of the best available.
You'se guys rock
Old Jun 12, 2008 | 05:33 PM
heavytruk's Avatar
heavytruk
You'se guys rock
click the supporter tab!
