Sponsored by: Real Truck
Trailer plug cracked
Old Feb 28, 2015 | 09:27 AM
BTJ350's Avatar
BTJ350
My '11 Super Duty, the 7 pole trailer plug does not have right trailer turn. I have a signal at the 4 pole however. All breakers/fuses are good. I achieve a right trailer signal only when pulling tension towards the left side when plugged in. My dealer says the only way to remedy this (under warranty) is to remove the cab and replace the main harness. I'm not very keen on that! I was going to splice a new 7 pole socket instead. Thoughts? Thanks!
Old Mar 1, 2015 | 03:12 AM
Yahiko's Avatar
Yahiko
Is it the socket that is bad? I though that, that was a easy replaceable item.
Well on my 06 it was and your problem might be farther up the harness.
Little screw on the back side of the plug and then unplug the body side
of the harness and install a new plug for the trailer to plug into.
Sean
Old Mar 1, 2015 | 06:28 AM
senix's Avatar
senix
Those plugs are easy to take off.
Check those wires connected it to. That is more like the problem.
If it turns out to be farther down the line then have them fix it under warranty.
Pulling the cab (if even required) is not a big deal these days.
Old Mar 1, 2015 | 07:07 AM
Irelands child's Avatar
Irelands child
No way would I have the cab pulled for a ten buck socket. The 'innards' are held by a screw - loosen it, slide the connector portion out and check the screw terminal connections. If they are secure, no broken pieces and there is still no power to that RH signal then see if a replacement internal connector will fit that socket. If not, then do as you suggested and wire in new one.
Old Mar 1, 2015 | 10:21 AM
ashleyroachclip's Avatar
ashleyroachclip
On my 99 the trailer harness unplug from he main harness.
There is no set screws holding the harness into the plug socket.
Again it is very easy to remove and replace.
You will need one from the same vintage truck, as I found that ford changed the wires around somewhere around 03 or so.
Old Mar 1, 2015 | 10:29 AM
ligito's Avatar
ligito
Ford seems to change harnesses almost annually/analy.
Parts go obsolete, very fast.
Might have to try one of the obsolete parts dealers.
Look into whether the harness just unplugs, like the vans do, I replaced the harness on my '02 E-350, pretty easy job.
chiefgeek69
May 19, 2019 09:25 PM
crucialprospect
17
Mar 31, 2018 03:57 PM
singleshot1
Apr 28, 2017 12:49 PM
freesoul
Feb 11, 2012 06:58 PM
Pest007
Jan 4, 2012 09:09 AM
