trailer plug issue....
Old Jan 1, 2012 | 10:55 PM
Pest007's Avatar
Pest007
Hey guys, I have a 1996 F250 Powerstroke, I am having an issue tracking down an electrical issue. I have a 7way plug on my truck, when I plug in a trailer, running lights, brake, 12volt, and electric brakes all work, except left side turn signal, the right side works, but not the left. The blinkers on the truck work fine, but I am not getting signal to the plug for only the left turn signal. I checked the plug it's self, and nothing, checked further up where the plug connects to the harness... same thing...nothing... like I siad, the signal on the truck markers work, but nothing going to the trailer plug... any ideas where to look?
__________________
Old Jan 1, 2012 | 11:05 PM
mountaineer27's Avatar
mountaineer27
The turn signals for my trailer plug are on a separate system. Is yours wired to the turn signals or on a separate fused system? I would take the plug and check the wires were they connect to it. They corrode there constantly
Old Jan 1, 2012 | 11:10 PM
fordpride's Avatar
fordpride
Check the fuses under the hood the trailer wiring is on it system
Pest007's Avatar
Pest007
I figured that they were on a separate system, I did unplug the connector from the harnes that feeds the trail plug, but I'm not even getting signal there.... where else could I check to see where the signal stops?
Old Jan 1, 2012 | 11:16 PM
Pest007's Avatar
Pest007
If it was a fuse issue, wouldn't both trailer blinkers NOT work, I mean everything else works except for the left turn signal for the trailer
Old Jan 1, 2012 | 11:17 PM
mountaineer27
The harness runs up the drivers side frame rail. Do you have a test light to poke wires?
Old Jan 2, 2012 | 12:01 AM
stainlessstroker95's Avatar
stainlessstroker95
You could just run a jumper wire from your tail light to the plug for your truck
Old Jan 2, 2012 | 07:06 AM
Hussler's Avatar
Hussler
If it's factory wiring then check fuse #7 10A in the engine compartment fuse box. That fuse protects trailer left turn lamp. Fuse #6 10A protects right turn lamp.
Old Jan 2, 2012 | 10:07 AM
farmert's Avatar
farmert
X2 on what Jim said.
Old Jan 2, 2012 | 02:12 PM
97XLT4X4's Avatar
97XLT4X4
is bulb in trailer good?
gotta start with easy stuff
Old Jan 3, 2012 | 09:30 PM
Pest007's Avatar
Pest007
Jim was right, it turned out to be the fuse, I forgot that our trucks run a separate fuse block just for that,,, Thanks guys!!
Old Jan 3, 2012 | 09:32 PM
fordpride's Avatar
fordpride
Ummmmmm^^^^^^^^^^^^^^^^
Old Jan 3, 2012 | 09:41 PM
oldbird1965's Avatar
oldbird1965
Jim for the kill, again!
Old Jan 3, 2012 | 09:48 PM
joe_13894's Avatar
joe_13894
Left and right are on separate fuses. The backup and marker lights share a common fuse.
Old Jan 4, 2012 | 09:09 AM
97XLT4X4's Avatar
97XLT4X4
fuses dont just pop.....find the root cause
Pest007
All Things Towing
Feb 12, 2016 01:32 PM
gmhill33
Aug 6, 2015 09:00 PM
TWDITMORE
1997 - 2003 F150
Mar 12, 2012 09:15 PM
Ole'Blu
Jun 16, 2009 06:35 PM
