Sponsored by: Real Truck
7.3 diesel
Old Feb 28, 2015 | 06:56 PM
Grizzly93's Avatar
Grizzly93
7.3 diesel
what kind of engine life can i expect out of the 7.3 in terms of miles?
Old Feb 28, 2015 | 08:01 PM
sgarder's Avatar
sgarder
Engine wise I am not sure. I have 220 thousand on my truck since I bought it. Not sure if previous owner replaced engine. 418,000 on truck. Others on 7.3 forum have up to 500,000 on truck with original engine with proper maintenance and an awareness of when things mechanical are going the wrong way.
Old Feb 28, 2015 | 08:14 PM
crb478's Avatar
crb478
With proper maintenance most will go 400+ thousand miles. I have personally never done it. I went 200K when my wife decided I need an new truck, so I now have a 2015 6.7. I can tell you at 200K the truck still ran perfectly and had many more miles to go. It had no signs of any wear when I sold it. It is a great motor. I can only hope the 6.7 is still running as strong when it get to 200K
Old Mar 1, 2015 | 10:25 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
If I remember right, the B10 is 200,000 miles and the B50 is 350,000 miles. Meaning 10% of units produced will need a major repair in the first 200k, and 50% will need a major repair in the first 350k. A major repair is typically anything that involves removing a cylinder head or the oil pan.
Old Mar 1, 2015 | 10:38 AM
fordman19762003's Avatar
fordman19762003
I know of one guy that has a '95 7.3 with over 500k on it, last I knew the only things he'd done to the truck was the clutch, starter, and transmission. I know of another guy that has 399k on his '00 7.3 with only a few bolt on parts replaced. If the motor is taken care of you should at least be able to get 300k out of it and 500k shouldn't be hard to reach either.
The body will probably be rusted out before the engine goes.
bpimm
General Diesel Discussion
Dec 19, 2013 02:57 PM
bigtexan99
21
Feb 27, 2011 01:11 PM
rollbutt
16
Mar 15, 2010 08:10 PM
roostercrows
26
Jun 19, 2008 08:00 PM
big eddie
Aug 20, 2006 09:13 AM
