Glow plug relay troubles...or computer?
I put a multimeter on it, the 2 small lugs are reading around 3.5-4 and the lug closest to the turbo is reading 12V give or take, when the key is off, the lug closest to the passenger side battery is reading nothing, when i turn the key, the lug closest to the passenger's side battery is reading 5V....Do I have the damn wires on backwards or is it just another bad relay? This is the THIRD one I've put in which didn't work...
Had a thought that the wires might be backwards... just went outside and changed the wires around, same exact thing...weird stuff, I have a Edge programmer and it doesn't have any codes either...any solution to this would be much appreciated. I have a Stancor relay in there right now, brand spankin new and the lug with the black wire/red stripe is 0 with key off, and only 5V with key on...the black wire with orange stripe is 12 with key on or off, and the 2 small lugs jump around 4.5ish
I'm really at a loss I need an expert!
Thanks in advance,
Larry
What are these relays you're getting? They're not the wrong (starter) relay are they? Starter relays usually ground through the mounting plate, so if that's what you have, the relay would be on all the time until it burned itself up.
With the right relay in there it doesn't really matter how you wire it so long as you hook up the wight sized wires to the right sized terminals.
Also, as a work around, if you're sure the truck is in park or neutral, take 2 screwdrivers with you, jump the GPR with one and when you're ready to start the truck, use the other one (or just take it off the GPR) and jump the two big terminals on the starter relay on the passenger side fender. Just be careful...
With the Stancor, I sure wouldn't think you would be having trouble with the relay itself. That's a serious piece of gear. I have the same relay in my truck and it hasn't given me a lick of trouble. So what I guess I would measure is the voltage on all 4 terminals with the key on (when the GPR should be running the GP's.). Measure that and report back and we should be able to get you squared away.
Like I said though, one of those small wires should measure 0V to a ground when the PCM is calling for the GPR to be running. That's how the PCM turns the GPR on. Rather than switching on and off the positive leg of the circuit, the PCM switches the negative side. It's safer that way and better for the electronics. If you get voltage on all 4 terminals, something isn't right in the wiring between the GPR and the PCM.
black wire with orange stripe = 12V/key on or off
small lugs = 4.5ish - 5V constant, key off or on don't matter with these dudes
Any ideas?
I really hope someone knows how to solve this one...I'm at a loss definitely
The one wire on the GPR should be a Pink wire with an orange stripe, correct?
That wire goes it pin 101 on the PCM. That's the wire the PCM grounds out to activate the system. If you're reading constant voltage on that one, then the PCM isn't getting it to ground for some reason. It could be that the wire is broken, or it could be that the PCM is not taking it to ground because it thinks your EOT (Engine Oil Temperature) is warm enough that it isn't needed. Do you have a way of reading live data from the PCM (AE, Aeroforce Interceptor, Torque, etc)?
You can either unbolt the connector from the PCM and ohm that wire out from there to the GPR or you can come up with a scanner that will tel us what the PCM is seeing for an EOT.
You can also ohm out the EOT sensor to see if it out of spec
K Ohms__Volts____TempF___Temp C
826______4.75______-32______-36
785______4.75______-30______-34
575______4.73______-22______-30
525______4.72______-20______-29
365______4.68______-10______-23
300______4.65______-4_______-20
250______4.63______0________-18
192______4.6_______10_______-12
173______4.55______14_______-10
139______4.49______20_______-7
103______4.4_______30_______-1
98_______4.38______32_______0
64_______4.18______40_______4
59_______4.13______50_______10
43_______3.92______60_______16
37.3_____3.8_______68_______20
33.6_____3.73______70_______21
26.8_____3.53______80_______27
24.3_____3.44______86_______30
21.5_____3.32______90_______32
17.2_____3.08______100______38
16.1_____3.01______104______40
13.9_____2.84______110______43
11.2_____2.59______120______49
10.9_____2.56______122______50
9.34_____2.38______130______54
7.55_____2.11______140______60
6.28_____1.89______150______66
5.34_____1.72______158______70
5.32_____1.71______160______71
4.48_____1.52______170______77
3.84_____1.37______176______80
3.75_____1.35______180______82
3.17_____1.18______190______88
2.8______1.09______194______90
2.68_____1.04______200______93
2.2______0.88______210______99
2.08_____0.86______212______100
1.87_____0.78______220______104
1.56_____0.67______230______110
1.33_____0.59______240______116
1.19_____0.53______248______120
0.38_____0.17______CEL Below This
This won't necessarily tell us what the PCM is seeing, but it will tell us if the sensor is bad.
Another trick you might try - run a jumper wire directly from the battery + to the terminal on the relay that takes the red/green wire. Then turn the key to RUN and listen for the relay to close. If it does, then you know the relay is good, and the PCM is properly completing the coil circuit. Leave it that way for 10-15 seconds and see if that helps with engine starting. If that all checks out, then there's something funky about the voltage supply to that red/green wire.
