starter relay probs
Old Apr 24, 2007 | 06:15 PM
knapikmichael's Avatar
knapikmichael
Angry starter relay probs
i took the starter relay off the one on the fender i may be wrong in calling it that but thats what autozone called it well i cant get the wires back on in the correct spots or some thing else is wrong can some one please tell me where they go i can start the truck by touching the the wire from the battery to the starter wire wire and the key will turn it off
Last edited by knapikmichael; Apr 24, 2007 at 06:49 PM. Reason: tryin to add an icon
Old Apr 24, 2007 | 09:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The starter relay was a common power distribution point on some years of the F series trucks.
There sould be two big terminals, the rear one has one wire on it that goes down to the starter solenoid.
The front big terminal may have several wires on it, one of which goes to the battery.
The other wires would put power into other circuits.
There should be only one small terminal, that wire runs to the key switch start terminal.
If they gave you a relay with two small terminals, look at the relay very closely.
You should see an I by one terminal and an S by the other.
The wire from the key switch goes to the terminal with the S by it.
The I terminal is not used.
Also check the mounting screws, the relay has to get a ground through the mounting screws to work.
Good luck.
Old Apr 25, 2007 | 06:08 AM
knapikmichael
thanks dave ill try it when i get home later and see what it does
Old May 3, 2007 | 03:57 PM
knapikmichael
tried it out truck starts but the srater stays engaged any sugestions
