Window issue... maybe someone has seen this
Old Feb 25, 2015 | 06:35 AM
Pocket's Avatar
Pocket
Front passenger window decided to start acting up. Worked flawlessly since the truck was new until this last week. Rolled it down from the driver's side switch, then later went to roll it up and nothing. Go to the passenger's door switch and it goes up and down fine. Hmmmm, ok. Sounds like a bad driver's side switch or poor connection to that switch.
So the wife hits it before I had a chance to tell her. Now she can't get it up with either switch. Nothing works.
I come home and take the passenger's side door off. Disconnecting and reconnecting the passenger's side switch causes it to work again. Tried the same for the driver's side and still nothing.
Haven't traced the wiring yet, so I don't know the exact cause. Mainly reaching out to see if anyone has had a similar issue to make my troubleshooting go quicker.
Thanks.
Old Feb 25, 2015 | 07:31 AM
bigb56's Avatar
bigb56
Try the drivers side switch while moving the drivers door back and forth to check for a broken wire in the harness between the body and the door.
Old Feb 25, 2015 | 08:46 AM
Submarine Docker's Avatar
Submarine Docker
My problem was like yours. It turned out to be driver's side window switch. Ordered switch assembly from Tousley's. Problem solved. About $60.
Good Luck,
Jim
Old Feb 25, 2015 | 08:57 AM
mueckster's Avatar
mueckster
Good Luck,
Jim
I found it to be the same issue on my friend's 2000 Crew Cab.
Old Feb 25, 2015 | 09:32 AM
F250_'s Avatar
F250_
Same here in my '03 Excursion when it only had about 150K miles. New DS switch took care of the problem.
Old Feb 25, 2015 | 10:02 AM
white Buffalo's Avatar
white Buffalo
Hijack -
Speaking of window problems, my Excursion drivers side window will go down fine until about 1/2 way then it gets real slow. Goes back up just fine in any location. Worried about using it when it's -10 tonight and getting stuck open. Motor assembly replacement, a little lube, or just wait till spring?
Old Feb 25, 2015 | 10:15 AM
jhl3's Avatar
jhl3
Originally Posted by white Buffalo
Hijack -
Silicone grease applied with q-tips in the tracks fixed the same problem on my truck. You have to pull the door panel though once it gets bad. It is a lot easier and less expensive than replacing a motor, which I had to do on my old X.
Old Feb 25, 2015 | 06:43 PM
white Buffalo
Thank you !
Old Feb 25, 2015 | 07:02 PM
whitetmw's Avatar
whitetmw
Perhaps these will help in your diagnosis.
Old Feb 25, 2015 | 07:27 PM
F350-6's Avatar
F350-6
I've had similar issues before. Cycling the key always got everything working again.
I've got the Rock Auto window switch replacement and it seems to be working fine for now.
Old Feb 25, 2015 | 09:41 PM
Pocket's Avatar
Pocket
That will do nicely sir.
Now I have to wait for the snow to go away.
Old Feb 25, 2015 | 11:07 PM
AllaboutMPG's Avatar
AllaboutMPG
You can try taking them out and liberally spraying them with electronic spray cleaner and the vigorously operating them. Don't use carb or brake cleaner you'll end up with a handful of melted plastic. Spray the cleaner so it gets inside the switch. I have a couple that were cleaned over a year ago and still going.
If that doesn't work these switches actually come apart pretty easy. Be gentle or you'll break the tabs. Be careful as you open them or little parts will fall out. A q-tip and alcohol will clean up corrosion. This could get you going until replacements can be had, especially if window is stuck down.
Old Feb 26, 2015 | 02:17 AM
mdierking's Avatar
mdierking
Change the drivers side switch out, the whole thing k it's causing the problem 150% sure
Old Feb 26, 2015 | 06:00 AM
timmyboy76's Avatar
timmyboy76
same scenerio here, a few years back. Pulled p/s paneling off and saw that the wires were cut/freyed. Their "ran" from outside panel/in, so it was a matter of time for the window to finish them of. Re-connected, tucked them away/taped better to paneling of door...walah.
Old Feb 26, 2015 | 08:47 AM
white Buffalo
Same here..............................
Nicmike
Jul 28, 2014 10:05 PM
SD Rick
Jan 26, 2013 06:35 PM
emik26
2004 - 2008 F150
Nov 26, 2011 09:25 AM
wileecoyote76
1997 - 2003 F150
Oct 28, 2004 08:53 AM
hughchi
Aerostar
Feb 16, 2004 03:04 PM
