C6 shift kit
Old Feb 23, 2015 | 02:31 PM
Gigemags05's Avatar
Gigemags05
C6 shift kit
I am thinking of putting a shift kit into my c6. I'm installing it onto a 351w with a mild build.
The truck will be a cruiser and joyride truck, but I want to make it fun to drive.
Oh yeah, the engine and tranny will be in a 47 pickup if that matters.
A few questions:
Will the shift kit shorten or prolong the life of the tranny in any way?
I want to know when it shifts, but don't necessarily need it to be the hardest shifter in the world. Any recommendations on specific kits?
Is this an upgrade you all think is worth it? Stupid?
Old Feb 23, 2015 | 02:58 PM
Franklin2's Avatar
Franklin2
It can prolong the life of the tranny, as long as you don't overdo it. They usually sell them in stages, or the kit has stages of firmness. Go up one notch over stock and you should be good.
Old Feb 23, 2015 | 04:35 PM
FordFETruck's Avatar
FordFETruck
Here's the kit I used.
http://www.ebay.com/itm/C6-FORD-SHIFT-CORRECTION-PACKAGE-KIT-SUPERIOR-TRANSMISSION-truck-transgo-valve-/230675707671?pt=Motors_Car_Truck_Parts_Accessories&hash=item35b557f717&vxp=mtr
I used the stage 1 kit with the optional firmer shifts spring. Shifts very nice and clean. Around town it shifts like a stocker, but cleaner and the more you step on it the firmer it shifts. Downshifts are nice and clean as well. Make sure to look at the code on your transmission servo cover and buy a new servo piston as well. Most are a molded rubber piece and are about $15. D codes and a couple others just use an aluminum piston and two O-Rings. Mine is an N code molded rubber piston and after 231,000 miles the sealing surface was worn off and the remains were sitting in the piston's bore, as well as it was hard as a rock.
Old Feb 24, 2015 | 07:11 PM
Gigemags05's Avatar
Gigemags05
Alright I'll look into that kit.
whisler
May 23, 2016 09:06 PM
twister2gt
Nov 6, 2009 08:46 AM
rlp
Oct 18, 2008 11:05 PM
79_custom
Jul 13, 2003 07:24 AM
frankie
Apr 19, 2000 01:00 PM
