If you have power on the wire going to the solenoid for starting, then ignition switch is bad, or you've melted wires together in the plug that goes to the ignition switch. My 77 camper special did that. Ignition switch was bad, shorted out and melted the harness. I ended up with a used harness from a 79, and the ignition switch harness plug is different. Ford new they had a problem and beefed up the switches in 79. So you need to get switch out of dash and take a good look at the plug and wires connected to it.
When I swapped the switch everything looked good with the plug. And I pulled the gauge cluster out to check on the wire harness to the switch and anymother visibles. Nothing melted. No red flags.
Faulty Starter Relay. If it's got that I terminal with factory plug, and you unplug that then the relay is at fault. If should only send power to the I terminal when relay is activated at start.
Later truck had this wire incorporated into the ignition switch to send full power to the coil.
I picked up a 2003 Expedition (5.4L) that has this odd problem. It will start just fine, but when you turn the key to the off position, it continues to run. To shut it off you turn the headlights on (when the key is removed), but the power is still on to everything. The only way to completely shut it down is to disconnect the battery.
I've swapped out the ignition module on the steering column. I've pulled the actual switch and it appears to function properly.
Any and all advice would be helpful. Thanks
did you ever get this fixed my truck is doing the same what was the issue
I just finished my build and now the truck will not turn off.
I went with a 3 wire gm alternator and pertronix distributor. The wire i choose to run the coil and electric choke both energize on/off with the key, Once the truck starts, it will not de-energize, Somehow getting voltage from the alternator. But the alt is very easy and i have used the same set up on other builds.
Thoughts?
Is it possible the exciter wire is generating 12 volts and feeding it back into my circuit? I have three wires from the old system, All are key on/off but whenthe engine is running they have 12 volts with the key off.
