Help! Problem Removing Ignition Lock Cylinder
So I have a little problem...
I bought my 2000 F-250 CCSB a while ago and it came with 2 keys - one for the ignition, and one for the doors/tailgate - may not seem like a big deal, but it annoys me to no end.
From my understanding, the truck had previously been stolen and had the driver's side lock punched, and then something happened to the ignition lock to where it had to be replaced - hence the different key. I finally got around to replacing all the locks so that I'd only have one key. I started with the doors, then moved to the ignition (which I thought would be the easy part). I've replaced several cylinders before and I know it should be simple, but for the life of me I can't get the cylinder out!
I push the detent, turn the key to run, wiggle and pull.... nothing. I can feel the detent push in, and the cylinder will move a little, but it won't come out. I'm not sure if this is something that just happens sometimes and there's a fix for it, or if I'm in a unique circumstance and my column was somehow damaged during the theft and that's what's causing it.
Any help would be much appreciated! Thanks in advance!
