Bad alternator
Old Feb 22, 2015 | 11:15 AM
jake_whitman's Avatar
jake_whitman
Bad alternator
What would be the effects of an alternator gone bad?
Old Feb 22, 2015 | 11:23 AM
Tedster9's Avatar
Tedster9
Dead battery?
Old Feb 22, 2015 | 11:27 AM
jake_whitman
Well when I go to start sometimes it'll act like my battery is going dead and then after a few cranks it'll go back to normal. I've also been having starting issues.
Old Feb 22, 2015 | 12:11 PM
Tedster9's Avatar
Tedster9
Could be. Loose, or corroded connections anywhere in the starting circuit will mimic a bad battery, very common mistake. Use your voltmeter to check charging voltage (after cleaning the battery posts and terminals, at the starter, at the engine block, etc) AND charging the battery thoroughly with an outboard charger. Clean and bright, shiny tight connections. Perform the checks and report back the voltages found at idle and say, 1500 RPM with headlights and heater on HI. Here's the link:
http://www.aa1car.com/library/charging_checks.htm
If the battery is more than five years old as a general rule it's best to replace it before causing any further trouble. They can last quite a bit longer than this, but that's not the way to bet.
Old Feb 22, 2015 | 09:09 PM
HIO Silver's Avatar
HIO Silver
The effect of a bad alternator?
... Driver Returns on Foot
... Found on Road, Dead.
Old Feb 24, 2015 | 03:29 PM
JEFFFAFA's Avatar
JEFFFAFA
Do you still have points in your Dizzy? Worn out points changes the engine's timing. The timing off can make it harder on the starter and cause the starter to spin slower.
WheelerJeremyS
Jun 20, 2018 07:44 PM
crestfallinman
33
Mar 1, 2012 09:54 AM
RangerPilot
1983 - 2012 Ranger & B-Series
Dec 5, 2007 12:25 PM
BillyBob69
1997 - 2003 F150
Nov 2, 2006 02:00 PM
demegod999
Mar 7, 2004 07:39 AM
