Need Electrical Help
Old Jun 18, 2018 | 01:12 PM
WheelerJeremyS's Avatar
WheelerJeremyS
Hey guys. I have a 1978 F100 that in the past week I have put a new starter, new battery, new alternator, new solenoid, and new voltage regulator on. It had been giving me electrical problems before but I just got it running after it sat for a a little over a year. Since putting the new stuff on I have had to replace the alternator this morning because the one I had put on from AutoZone was bad. I'm not sure if it was bad from the get go or went bad once on my truck but for some reason it wasn't charging the battery and now the new alternator isn't charging it either because it died on me (I think died due to fuel pump issues) but wouldn't start and battery is completely dead again after 100% charge this morning. Any idea what I am missing?
Old Jun 18, 2018 | 01:44 PM
Tedster9's Avatar
Tedster9
Welcome to FTE Jeremy
Well, going only from the information provided, it sounds like you've got a defective battery, at minimum.
The only way dignostics can be done effectively though, especially over the internet, is one step at a time. And a fully charged, serviceable battery is the first thing to check for. It's important to do these tests in order and methodically, because while a defective alternator can ruin a good battery, a defective battery can also ruin a good alternator!
SO, the first question would have to be is A. How old is the battery, and B. what kind of charger specifically was used? Maybe you know all this stuff already, but since you are new here at FTE, nobody knows what your skill level or knowledge base is.
Old Jun 18, 2018 | 04:51 PM
WheelerJeremyS
My knowledge is practically bumpkis. I inherited The truck a few years ago from my wife's grandfather. Both the battery and alternator were brand new last Sunday. Since then I have taken the battery back to AutoZone several times and whatever brand tester and charger they use there is what was used. I actually left it with them last night for them to charge and check and they say the battery is good just not getting charged from the alternator. Also of importance, after putting new alternator and charged battery on this morning had retested at different AutoZone after an hour of drive time. Battery tested at 96% but only 12.4 volts while running.
Old Jun 18, 2018 | 05:08 PM
Tedster9's Avatar
Tedster9
OK, tracking now with where we're at. 12.4 volts is pretty low. It doesn't sound like they know how to charge a battery. Or, the alternator is toast. If you had your own charger, you wouldn't have to depend on them, just sayin'. If you want to do your own maintenance, it's a necessity.
Anyway make sure all the ground and battery connection cables at both ends are clean and tightened securely, same with alternator wires and connections. The belt needs to be tensioned properly too, if it's loose it will not charge the battery. If the battery cables starter and ground cables are original, these should be replaced.
When measuring for charging, do this right at the battery posts. Should see 13.8 to 14.3 volts at idle. Then, turn on all the headlights, radio, heater fan on HI, etc to test the alternator under load. Rev the motor up to a fast steady idle around 2000 RPM for several seconds. It should still measure in the high 13s or better. If not, the alternator is most likely defective.
Old Jun 18, 2018 | 05:53 PM
Filthy Beast's Avatar
Filthy Beast
Agree with Tedster9 about cleaning up the basics...like a fully charged battery...clean and tight battery (or any electrical connections) connections, solenoid connections..make sure the solenoid is grounded to a clean piece of the fendewell - the mounting screws are the holdowns for the solenoid's ground.....clean and tight engine to cab grounds, etc.
Once that is a known, we can start troubleshooting other "knowns"....such as alternator AC ripple (will test the diodes), or full fielding the alternator - will test the alternator's output, or..not to spec output which would either confirm or deny regulator problems or alternator problems.
But first, clean up the basics as stated before.
Old Jun 19, 2018 | 10:19 AM
niko20's Avatar
niko20
Wait - you said you measured only 12.4 volts while running? That means your alternator ain't doing something it is supposed to.
And I wouldn't be surprised if you may have just killed the brand new battery cause it wasn't charging. A lead acid battery's life is greatly reduced when it goes under voltage. You should see almost 14 volts at the battery when the vehicle is idling.
Old Jun 19, 2018 | 01:57 PM
User 32921's Avatar
User 32921
Is there a reliable way to test that the cables are doing their job well? I've had issues living by the beach with battery/starter cables giving me intermittent issues until I replaced them. Cutting them open revealed corrosion/build-up on the inside but they appeared perfect on the outside. Cables are usually my go-to fix when experiencing weak starting/charging/intermittent electrical issues.
Tip for getting that alternator belt nice and tight: use a pry-bar or something to push the alternator until the belt is tight (or have someone help you) while the bolt is tightened.
Old Jun 19, 2018 | 02:33 PM
DB429SCJ's Avatar
DB429SCJ
Check the connector at the regulator for corrosion or broken wires. New ones are available at NAPA .https://www.napaonline.com/en/p/ECHVRC428
Old Jun 19, 2018 | 03:03 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I always have a new alternator or starter bench tested before I walk out the store. X2 on ck and clean all elec connections. New cable are not that much and then you take that possibility out of the equation.
Old Jun 19, 2018 | 03:04 PM
Tedster9's Avatar
Tedster9
The only reliable way to test is while they are energized, under load, for "voltage drop". But if they are original they are for certain way past the "best by" date and need replacing. Any resistance in the cables and connections will rob the charging system of current capacity and chronic undercharging I'd expect. You're right, cables can look just fine and be completely defective.
Old Jun 20, 2018 | 07:44 PM
1STFOX's Avatar
1STFOX
My '78 Fairmont was only putting out 12.4v too.. Turned out to be the voltage regulator in my case... You might want to
check yours with a known good one..Oh, make sure the regulator is grounded well too!
Tman_417
Jul 27, 2014 10:42 PM
SpawnX
1983 - 2012 Ranger & B-Series
19
Apr 25, 2014 07:53 AM
crestfallinman
33
Mar 1, 2012 09:54 AM
RangerPilot
Dec 5, 2007 12:25 PM
twowheledfreak
Oct 19, 2004 07:21 PM
